Go to Post We want to go out and build something right away. But it is better to think a little bit first. - ChrisH [more]
Unread 01-02-2010, 18:40
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Gaming adapter power problem
Our team is having some trouble connecting our gaming adapter to the power distribution board. Where should we hook it up?
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 01-02-2010, 18:56
Andrew@CGW Andrew@CGW is offline
FRC #2996 (Cougars Gone Wired)
Team Role: Electrical
Andrew@CGW is an unknown quantity at this point
Re: Gaming adapter power problem
It plugs into the 12v DC socket next to the cRIO power socket.
Unread 01-02-2010, 18:58
AKA: James
We tried that, but it didn't work. Is there any way to tell which wire is + or -?
Unread 01-02-2010, 20:01
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
It sounds like you could use the power distribution schematic.
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
Unread 01-02-2010, 20:04
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
The wire with the white stripe is positive.
Unread 01-02-2010, 20:09
The white stripe indicates POSITIVE.
Wire it in reverse and the wireless adaptor will burn out.
Of course, if you've already wired it backwards, then you probably need to buy a WET610N as a replacement.
Last edited by Mark McLeod : 01-02-2010 at 21:45. Reason: Hastypickle isn't so hasty
Unread 01-02-2010, 20:13
Originally Posted by Hastypickle View Post
I believe the wire with the white stripe on it is the negative wire.
That is incorrect. The wire with the white stripe is the positive wire.
Unread 01-02-2010, 20:22
AKA: Nicholas
FRC #1703 (Rats)
Originally Posted by Mark McLeod View Post
AAAAAgh!
No, the white stripe indicates POSITIVE.
Whoops. I didn't have anything to check if I was correct so I added the "I believe" at the beginning. I should probably remember that for future information though. Thanks for correcting me.
Unread 01-02-2010, 20:44
Get the documentation from the http://www.usfirst.org/frccontrolsystem page. The information you want is on page 8 of the Chapter 3 document.
Note: it is the positive wire which bears the stripe.
Unread 03-02-2010, 21:15
Grant U Grant U is offline
FRC #2594
Grant U is an unknown quantity at this point
We have successfully powered the wireless game controller. The wire with the white stripe is, indeed, the positive connection.
Unread 06-02-2010, 16:01
AKA: James
Thanks! As it turned out, we did in fact fry it, but we got a new one and it's working great. Thanks!
2009 Gaming Adapter not working after reset MartinB FRC Control System 4 25-01-2010 00:02
Linksys WGA600N-RM Dual Band Wireless-N Gaming Adapter westy92 Control System 2 20-09-2009 14:36
Linksys Gaming adapter Phoenix Spud FRC Control System 6 04-02-2009 01:01
Fubar Gaming Adapter Lord Byron FRC Control System 4 15-01-2009 17:43
Gaming Adapter Orientation On Robot: Does it matter? Tom Line FRC Control System 1 12-01-2009 12:48
