Go to Post Let’s not scare the newbies away, let’s welcome them and help them. - Arefin Bari [more]
Unread 23-01-2009, 05:52
Delvadar Delvadar is offline
FRC #2217
Delvadar is an unknown quantity at this point
Labview servo programming
Can someone help me program servo please?
I tried everything and I get the same errors again and again...
(something with the case structure).
Unread 23-01-2009, 08:32
Re: Labview servo programming
What are you trying, and what errors are you getting?
What do you want the servo to do?
How do you want to control what the servo does?
When do you want the servo to move?
Unread 23-01-2009, 14:26
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Errors are always accompanied with an error code and explanation. Posting these as well as screen shots of your code will be very beneficial to the community.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 24-01-2009, 10:39
FRC #2217
I want the servo to move the camera.
there is two servoes connected to the camera.
one moves the camera up and down and one moves the camera right and left.
Unread 24-01-2009, 19:54
Unread 25-01-2009, 06:52
FRC #2217
The Servo moves the camera(I will picture it tomorrow).
The servo is autonomic so it moves by itself.
I need to know how to connect it with labview.
I will send you picture tomorrow.
Unread 25-01-2009, 11:02
I don't understand your issue fully, but my suggestion would be to open the LV vision example for the gimbal mounted, servo controlled camera. There is one for single color tracking, and one for the pink/green target. They require that you have the driver station connected and enabled, that you have the digital side car connected to slot four and power, that you have the jumpers on the correct PWM channels, and that you set the panel servo IDs to match your X and Y ports used on the side car.
It is far more likely that you'll get this to work, then you can look at the diagram and compare to what you've been doing, including running them both with probes to compare how they operate.
Greg McKaskle
Unread 28-01-2010, 15:31
Andrew0089 Andrew0089 is offline
FRC #3229
Andrew0089 is an unknown quantity at this point
Unhappy Re: Labview servo programming
We have set this up multiple times and we have failed! we do not know how to get them to turn we are using all FRC programs to test the servos movement. si we know it can not be programming. PLEASE HELP
Unread 01-02-2010, 20:02
BLProgram2010's Avatar
BLProgram2010 BLProgram2010 is offline
FRC #2534 (Robo Lake)
BLProgram2010 is an unknown quantity at this point
weve gotten the servos to move at a press of a button but, we when we press the button they move all the way. how do them to move at a smaller degree?
Unread 01-02-2010, 20:29
Use a smaller number as the set position, perhaps?
Programming into Servo?? Team2883 Programming 1 18-01-2009 18:56
servo Twiching in Labview Sykan NI LabVIEW 2 15-01-2009 10:46
Servo Programming Again..... programmr Programming 1 14-02-2008 09:31
HS-322D servo programming question JimHull Programming 12 10-02-2007 15:14
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
