Go to Post OUR CNC machine is named Joe, and he has this week of school off. He eats candy instead of electricity. Not so accurate or repeatable, but very easy to re-program. - Not2B [more]
Unread 01-02-2010, 15:55
jaketessem's Avatar
jaketessem jaketessem is offline
3292
FRC #3292 (The Aluminum Falcon)
jaketessem is an unknown quantity at this point
Movement Troubles
We have attained wireless movement with our robot and everything is working properly... except that when we move our joystick right our robot turns left and when we move our joystick left our robot moves right. Please Help!!!
Unread 01-02-2010, 15:57
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Movement Troubles
Do forward and back behave properly? If so, you can probably just physically swap the left and right PWMs or the connections to the motors.
If you'd like to get into the code, you'd have to let us know which environment you are using (LabVIEW, WindRiver, Java).
Aren't signatures a bit outdated?
Unread 01-02-2010, 16:10
jaketessem's Avatar
3292
forward and back are the same, and we use labview
Unread 01-02-2010, 20:30
The question was
The answer was
Since that doesn't answer the question, nobody can tell you whether you accidentally swapped the PWM channels, whether you need to invert the motor inputs on Open, or both.
There are four combinations, so you can try all four and see which works better, you can look carefully at the wiring and the code and make sure that the PWM are correct and try the combinations of invert, or you can describe the behaviors with more detail and someone can help you debug.
Either way, I'm sure you'll get it working quickly.
Greg McKaskle
Unread 05-02-2010, 16:33
jaketessem's Avatar
3292
Forward and back behave properly, but when we move our joystick left our robot goes right and when we move our joystick right our robot moves left. We tried switching the wires around on our Jaguar brand PWM's but that reversed forward and back, but did not fix left and right.
We use Labview, if there is a programming solution then please help me in finding it.
Unread 05-02-2010, 16:36
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
I believe changing PWMs between left and right and changing which motor is inverted in the code should solve the problem.
I'm not absolutely sure this is correct so hopefully if I'm completely wrong somebody will hop in before you bother to try it.
Movement Hunter1539 Rules/Strategy 4 09-01-2008 22:06
Remote troubles atowle1236 General Forum 4 07-01-2008 00:11
Camera Troubles cmurdoch Programming 9 11-02-2006 11:34
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
