Go to Post I have trouble believing that there's really a regional that isn't fun... - psquared89 [more]
Unread 01-02-2010, 20:37
Thundr Whale Thundr Whale is offline
FRC #3299
Thundr Whale is an unknown quantity at this point
Trouble woth the jaguars
While using one of our jaguars it overheated so we are looking to put fans on it. Have any other teams done this and if so how?
Unread 01-02-2010, 20:49
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: Trouble woth the jaguars
We have been using ours for a solid year and it has never had an issue with over heating, even with all the dust problems last year (our ball mechanism blew a LOT of air)
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The Jaguars have integrated fans, so no extra cooling should be necessary. Check to see if that fan is running.
How much runtime does it take for them to heat up? What kind of loading are they under? They should heat up a bit because of the way they operate. They switch FET's at 15khz, under 40+ amps of spiike load, so they should generate some heat.
Did they release smoke? If so they are dead.
Kettering Motorsports
Unread 02-02-2010, 08:52
Thunder,
In exactly what way did it overheat? Was it smoking, just hot to the touch, or did it tell you so via CAN bus? It is not likely to get hot under normal conditions. However, if you say that the motor it was feeding was also hot and so to the wires it is connected to, then yes it could get how. That is an indication that you are running near max currents on the motors your are using. Max current on the CIM is 129 amps which over a length of time will heat all components in the electrical system feeding that motor. The power FETS used in both the Victors and the Jags are rated for 40+amps each and there are three FETs wired in parallel which should handle the loads we have.
If the Jaguar was smoking, it is likely damaged. If it reported over temp on the CAN bus but was not hot to the touch, you may have an error elsewhere.
Unread 02-02-2010, 09:58
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Were the Jaguars faulting (slow blink red) while driving your system? A slow blink red indicates there was some type of fault; two examples are over current and over temperature.
The over current fault will reset in a short period of time, while the over temp will only reset when the internal Jaguar temperature falls below the threshold.
Unread 02-02-2010, 10:22
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Make sure to give the Jaguars's some room between each other. Unlike Victors, that have open components to let air escape, the Jaguars have vents in the plastic for the heat to escape from.
The manual recommends 1/2" of clearance. It also shows fault conditions.
Since you haven't answered how you know it's overheating, and since I'm still weary of a Jaguar actually overheating in regular use, I would check to make sure the limit switch jumpers are secured in place.
I don't believe this to be an over current or power supply under-voltage since you never mentioned more than one Jaguar doing this, and you hopefully have it attached to an FRC legal breaker.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
What do you think of the jaguars? Mechanical Electrical 76 12-06-2009 17:24
Advantages of the Jaguars? EricVicenti Electrical 36 03-03-2009 20:16
Connecting to cRio, getting the jaguars to go solid yellow.... then nothing. DSST\neal.ian FRC Control System 11 30-01-2009 18:15
Programming the Jaguars RyanJK NI LabVIEW 1 24-01-2009 18:41
