Go to Post It would be better as the software person to preach to your team early on for non-reliance on software. - Tom Bottiglieri [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 21-01-2010, 17:03
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Pro/ENGINEER Configuration Tips
Hi,
I'd like to open a new thread on changing some default options in Pro/ENGINEER to share with everyone. Hopefully some of the other mentors will have some good suggestions too! Here are a handful of good ones I use on a regular basis.
Enable the Preview Window in File Open Always:
file_open_preview_default expanded
Start Pro/E with the Main Window Fully Maximized
open_window_maximized yes
Initial Display of Datum Features
display_axes yes/no
display_coord_sys yes/no
display_planes yes/no
display_points yes/no
Always Open Files from the Working Directory
file_open_default_folder working_directory
Running Pro/E on a Low-End Graphics Card
graphics win32_gdi (opengl is the default)
Use the Default TrueType Font for On-Screen Notes
default_font ttf_font.ndx
PS. Tools, Options is where you change any configuration options ;-)
Unread 01-02-2010, 21:21
skotmorris's Avatar
Thumbs up Re: Pro/ENGINEER Configuration Tips
Hi,
If you are working with moving parts with joint definitions, there is a cool config.pro option that will allow pushing parts with moving parts. This can be very useful when you have designs that are moving but not always in contact with each other.
enable_advance_collision yes
Definitely good to use in the design, idea or prototype stage before you have a fully defined and constrained mechanism. Once you have enabled this option, you must turn on the push option in the assembly settings by picking Tools, Assembly Settings, Collision Detection. This will open the Collision Detection Settings dialog box where you should set General Settings to Global Collision Detection and set Optional Settings to Push Objects on Collision, OK.
Unread 10-02-2010, 19:14
jhouser's Avatar
jhouser jhouser is offline
MCAD $@#$@#$@#$@#$@#., Pelco
FRC #1671 (Team 1671)
jhouser will become famous soon enough
So I have a question for using mechanism dynamics. Are you replacing all the electronics with a single block with a mass that approximates your electronics, or did you redefine the neutral files for the electronics to have mass?
Josh Houser
Mentor, Team 1671
MCAD Tools Administrator, Pelco
Clovis, CA
Unread 11-02-2010, 00:09
ligerbots ligerbots is offline
AKA: Elie GLik
FRC #2877 (Ligerbots)
ligerbots is an unknown quantity at this point
Send a message via AIM to ligerbots
After you enable the collision, what exactly do you do to be able to move parts around and see where they interfere with each other?
Also I'm not sure if my changes got saved to the config file as when I open ProE, it opens restored and not maximized. I just set the config file in my active working directory, right?
Unread 11-02-2010, 19:11
jhouser's Avatar
Sorry for the long response. I think the configuration question you have is most important right now, but I'll answer the mechanism portion first.
Enabling collision is most useful in running a mechanism analysis. This is where you apply motors and forces and run your mechanism for a duration of time and it then you can measure outputs such as speed, torque, acceleration, etc.
When you did your initial install, you entered a "Start In" directory, this is one of the places that Pro/E gets configurations. If you right click on the shortcut you use to start Pro/E, it will show you your "Start In" location. This is typically where you'll want to save changes. You can do a search of your directories for the config.pro file if it's not in your "Start In" location.
I've been using XP for a long time and I'm seeing different things happen with Vista or Windows 7. You may not have rights to your "Start In" folder, so you may need to move it somewhere else.
Finally, make sure it saves as config.pro in your start-in location.
Josh Houser
Mentor, Team 1671
Clovis, CA
Unread 12-02-2010, 00:08
skotmorris's Avatar
Elie, in order to get the parts to move, you must change their static constraints to mechanism constraints. Pro/E supports numerous joint connections besides the traditional mate, align, insert.
I am using the collision option with the Burlington team becuase they are using a cam driven design, but the cam is not always in contact with the follower. Otherwise I could use the cam/follower connection.
If you want some help with joint connections and getting motion into your assemlby, just lemme know. I am open on Wed/Thr next week.
Unread 15-02-2010, 09:52
AKA: Elie GLik
Hey, Thanks for your reply. I'm not actually sure that at this point we need a more detailed CAD drawing, but I was just interested in how it could be done because I ran into a similar problem when I was trying to build a latching hook. If you have any reference materials handy or could point me in the right direction when creating those joints that would be awesome! I'll try and make a more detailed model after the build season so we have it for reference next year.
Thanks
Unread 04-02-2012, 16:39
sthrondset sthrondset is offline
FRC #3875
sthrondset is an unknown quantity at this point
I have not been able to change the default config.pro file.
Any help would be appreciated!
Unread 06-02-2012, 08:31
skotmorris's Avatar
Save a copy of the default config.pro file to you My Documents folder. You can do this in Windows or Creo. Once located in your My Documents folder, you will be able to change it in any way you want to. When Creo is started, it will look for a config.pro file in My Documents and load it on startup.
-Scott
How to get Pro/Engineer? Shoubakka Pro ENGINEER / Creo 12 11-09-2010 22:19
Is your team using Pro/ENGINEER? skotmorris CAD 3 02-02-2010 21:24
PTC KOP Start Parts for Pro/ENGINEER skotmorris Pro ENGINEER / Creo 0 21-01-2010 13:37
Pro/Engineer To Inventor jujuninja Inventor 5 19-01-2010 15:22
FIRST Workshop - Pro/ENGINEER PTC_FRC CAD 0 28-09-2009 13:16
