Go to Post Feelings are like the laws of physics: if some one feels offended or alienated, then they are offended or alienated - it doesnt matter why you dropped a hammer, if it falls on someones head they will be hurt. You cant expect it to not hurt, because you did not intend to hurt them. - KenWittlief [more]
Unread 01-02-2010, 22:05
Thxe Thxe is offline
FRC #2535
Thxe is an unknown quantity at this point
Problems with the watchdog (I think)
Hello, we are having some problems with getting our code to work. At first, whenever we put the robot into enabled mode, it would immediately say watchdog not fed. The thing is, we are feeding the watch dog. I commented out the camera related code, which helped a lot, but consistently, about 2 minutes after the robot is turned on, it dies to the watch dog. I have the watch dog set to 100ms time out, which seems like plenty of time, especially considering that we don't have much code yet. All we have is a bit of camera initialization (which I commented out anyway) and the code to control the mecanum wheels.
I have resolved the problem if I comment out all code except the feed statement, so I'm confident that that is working.
Anyways, does anyone have any idea what could because the watch dog to trigger? I also tried setting the time out up to 1000 which had no effect so I'm a little confused.
Problem with System Watchdog JSonntag NI LabVIEW 14 20-02-2010 11:31
System: Watchdog problems dboisvert C/C++ 7 16-02-2009 02:36
System: Watchdog problems dboisvert C/C++ 1 15-02-2009 20:12
Problems with the manual of the green target (for cmu cam) Kawashima Kit & Additional Hardware 1 28-01-2007 13:31
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
