Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 31-01-2010, 20:18
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
KOP Mangetic Encoders Don't Spin Full 360
Hello, today I was using the KOP magnetic encoders in analog mode. To my understanding, It should read 0 volts at 0 degrees, and 5 volts at 360 degrees, and vary linearly in between. However, It seems that they reach 5 volts at about 270 degrees, and reset after that. This is true for both the encoders in the kit. Perhaps the magnet is not properly centered on the chip? If so, it is strange that they are both reseting at a similar angle. Has anyone else experienced this? Thanks for any help.
Unread 31-01-2010, 21:41
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Re: KOP Mangetic Encoders Don't Spin Full 360
Our mag encoders do not have dead spots. We are reading them over SPI.
Unread 01-02-2010, 19:43
FRC #1700
Its not so much a dead spot, but it read 0 volts at 0 degrees, 5 (or 0) volts at 270 degrees, and if i keep spinning, reads 5 volts again at 180 degrees
Unread 01-02-2010, 20:24
What you describe doesn't make sense. How are you testing this? It might make things clearer if you showed us a picture of your setup.
Unread 01-02-2010, 23:52
FRC #1700
Perhaps the attached image will help. We are measuring the value with a voltmeter and outputing the number to the DS, and they match. The values are the voltage multiplied by 72 to convert it to degrees. So 0 volts is 0 degrees, and 360 is 5 volts
Unread 02-02-2010, 10:22
AKA: Mark
Does the location of the border between 0 and 5 volts change over several rotations? Just to verify, you have a proper setup (magnet centered over the chip with an air gap of less than 2 mm) and aren't spinning the magnet in your fingers or something, right?
Unread 02-02-2010, 10:32
bcieslak
Posts: n/a
An encoder sends out a stream of 0V to 5V pulses as it rotates...Don;t look for anything voltages in between. They are digital not analog.. Not sure about the KOP encoder but typically you get 1024 pulses per revolution. .Your code counts pulses and the time between the pulses to get the information it needs. And there are 2 channels putting out pulses but they are out of phase with each other. Using that difference you can determine the direction the axis is turning. Use an oscilloscope to test the outputs and observe the pulse train...
BC
Unread 02-02-2010, 10:55
Jared Russell's Avatar
Taking a year (mostly) off
BC
This is for a quadrature-type (optical) encoder. The original poster is describing the magnetic encoder that came in the kit of parts this year.
Unread 02-02-2010, 11:55
You're not telling us the whole story. Your green numbers can't get as high as the picture shows them reaching.
What is your magnet affixed to, and in what orientation relative to the sensor?
Unread 02-02-2010, 18:34
FRC #1700
The magnet is fixed to an axle, above which is the chip, mounted on a lexan bracket. The chip is pretty freaking close, but I'll check it out tonight and make sure it is close enough.
I made a mistake in describing the picture. The white numbers show how far it has turned, and the green numbers show how far it would think it has turned (both over multiple revolutions). Take that number modulo 360, and it'll give you the degrees it reads. Sorry about that. I'll try to get some pictures tonight of the setup, if it'll help.
Attaching KoP encoders DarKCroNo Electrical 4 04-02-2009 17:23
KoP Quadrature Encoders ComradeNikolai Sensors 1 22-01-2009 14:22
2009 KoP Wheel broken (already) - don't drop them! DonRotolo Kit & Additional Hardware 2 17-01-2009 13:12
Don't Do What Seanny Don't Does Mike Iantorno General Forum 38 05-02-2003 23:56
