Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
Unread 01-02-2010, 20:37
dwodrich dwodrich is offline
FRC #1706
dwodrich has a spectacular aura aboutdwodrich has a spectacular aura aboutdwodrich has a spectacular aura about
Holonomic issues
I have validated that the wheels are mounted correctly "x" from the top "o" from the bottom.
I have validated that we are sending in the correct vector in degrees. 0 for straight ahead.
We can move forward with 0 and backward with 180 when motors on one side are inverted. But we have no ability to strafe. The motors are each side are fighting each other.
When we change the motors so that none are inverted. We can strafe side to side with no issues, but we can no longer go forward or backwards.
Check polarity on all the jags.
Anyone have any ideas? seems like we are making a simple mistake.
Unread 01-02-2010, 20:49
FRC #1706
Re: Holonomic issues
I'm not at the robot to check, but could this behavior be explained by a PWM cable switched sid to side?
Unread 01-02-2010, 20:51
TOP VIEW of robot:
front
1......2
3......4
rear
numbers in chart above refer to the wheels.
wheel#1 is front left
wheel#2 is front right
wheel#3 is rear left
wheel#4 is rear right
Put the 'bot up on blocks and test it with all six commands (fwd/rev, slide left/right, spin clockwise/counterclockwise) and tell us which direction each of the four wheels is being driven for the different commands.
Here's what you should get:
forward command: all 4 wheels spinnning forward
reverse command: all 4 wheels spinning reverse
slide right command: wheels 1 & 4 spinning forward; wheels 2 & 3 spinning backward
slide left command: exact opposite of slide right
spin right: wheels 1 & 3 spinning forward; wheels 2 & 4 spinning backwards
spin left: exact opposite of spin right
download this PDF file and carefully study the chart at the bottom left of the page:
http://lib.store.yahoo.net/lib/yhst-...lSpecSheet.pdf
Unread 01-02-2010, 20:59
I can't think of anything simple that would cause what you're describing.
What happens when you try to rotate?
Can you show us your 4-motor drive open code?
Unread 01-02-2010, 21:03
FRC #1706
Not at the robot now, but I did that, when strafing both front were turning the same direction and both back were turning the same direction but the opposite of the front.
I am now thinking that maybe the PWM cables are switched front to bakc on one side. I think that would cause one side to fight the other in this way.
and changing the inversion of one side would then fix the side to side strafing, but brake the forward-backward motion.
Unread 01-02-2010, 21:10
dwodrich, I updated my earlier post with more detail:
http://www.chiefdelphi.com/forums/showpost.php?p=911502
Unread 01-02-2010, 22:32
I know you said you validated the wheel configuration, but I urge you to check it again. If turning both front wheels in the same direction makes the robot go sideways, the rollers are apparently oriented the same way. Same for the back ones. Having them in an incorrect >> orientation could explain the behavior you described.
Unread 01-02-2010, 22:35
What you described above is not a valid set of wheel commands for mecanum.
valid mecanum wheel commands explained here
Unread 02-02-2010, 00:58
bakketti bakketti is offline
FRC #0443 (Freelance Robotics)
bakketti is an unknown quantity at this point
dwodrich - My team is having a similar problem. Left and right slide work but forward/backwards have the front and rear wheels fighting each other:
We are simulating the code on our computers with PWM indicators and a USB joystick just fine. So it makes me believe its a hardware issue. ... Not sure what though.
Keep us posted if you figure out something.
Unread 02-02-2010, 08:20
FRC #1706
left side inverted:
forward command: all 4 wheels spinnning forward - goes forward
***this is what we get
reverse command: all 4 wheels spinning reverse - goes backward
***This is what we get
***we get 1&2 spinning forward and 3&4 spinning backward - won't go anywhere
***we get 3&4 spinning forward and 1&2 spinning backward - won't go anywhere
When we do not invert one side we get:
forward command: all 4 wheels spinnning forward - won't go anywhere
***front wheel spinning forward back wheels spinning backward
reverse command: all 4 wheels spinning reverse - won't go anywhere
***front wheel spinning backward back wheels spinning foreward
***this is what we get - slides right
***this is what we get - slides left
I will check tonight when we get to the robot. We must have the left side of the robots PWM cables reversed on the digital side car. We are using the electronics board from last years robot and I know the PWM cables are bundled and zip tied. I also don't remember checking the digital side car end. We called out the PWM location by looking at the label we put on the PWM last year.
Thanks for all the idease! I'll post the solution when we get it figured out, hopefuly tonight.
Unread 02-02-2010, 10:20
left side inverted:
what do the wheels do when you give a spin command (clockwise and counterclockwise)?
If you map out what each of the four wheels are doing for each of the six commands, you can figure out what wires to swap, or, alternatively, you can fix it in software.
Unread 02-02-2010, 21:19
FRC #1706
left side inverted:
It was the PWM cables. The ones on the left side were reversed. Drives like a charm now.
Holonomic drive angle? dwodrich NI LabVIEW 17 05-02-2010 09:39
Holonomic vs Mecanum Help!! kSniper Technical Discussion 10 25-03-2008 16:57
Holonomic Programming??? sknkmeistermatt Programming 2 12-02-2008 15:47
Holonomic... Greg Perkins Technical Discussion 2 02-02-2005 11:59
holonomic drives Max Lobovsky Technical Discussion 5 10-03-2004 21:31
