Go to Post Don't forget the robot, the most important hardware there is!:p - artK [more]
Unread 01-02-2010, 20:48
Larrys_Panther Larrys_Panther is offline
Frankfort High School - Mentor
AKA: Larry Storie
FRC #2245
Larrys_Panther is an unknown quantity at this point
What are you using to Latch A Kicking Device
Other than a common door latch what is being used to latch a kicking divice under pressure and release it when wanted?
Unread 01-02-2010, 21:48
Chris is me's Avatar
AKA: Pinecone
Re: What are you using to Latch A Kicking Device
Just grabbed a picture. Bolted onto the prototype side rail, so just pretend that acrylic is actually aluminum.
Unread 01-02-2010, 22:06
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
We don't have it assembled yet, but our plan is to use a gate latch.
The latch part itself is attached to the back side of the kicker (length of chassis frame), cylinder extends, hooks itself into the latch, pulls back. When it gets to a certain point, there will be some obstruction tripping the latch, firing the kicker.
Unread 01-02-2010, 22:26
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I am not Mechanical, but we used this on our 2008 robot to launch a giant sling shot, and it never failed once, and we could put a "safety pin" in it to keep it from firing.
http://www.chiefdelphi.com/media/photos/30674
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 01-02-2010, 22:27
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Magic.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 02-02-2010, 01:10
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Does anyone using this latch scheme plan to kick with variable force too? If so, will it be varable pneumatic, variable bungee/winder, or variable pneumatic-bungee combo?
Unread 02-02-2010, 01:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
We will be using a latch on our variable power surgical tubing kicker. The kicker consists of two carriages on linear rails. The back carriage has the latch and is driven by a lead screw. The front carriage is attached to the surgical tubing and is accelerated forward when the latch is released.
Unread 02-02-2010, 01:39
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
I know of at least one team that would be using a contraption that grips onto nylon tie-down straps. The easiest way is to use a small pneumatic cylinder. Mount the cylinder on an angle, attach a piece of metal to the cylinder shaft along with a tread like material to the bottom. With a base plate, the cylinder will not let the rope budge at all. If you mount the end of the cylinder to the left and the front to the right on a steep downward angle, you would be able to have the kicker to the right and the winch system to the left of the cylinder. The rope will budge very little if the system is set up in the opposite direction. The force of the cylinder pushing downward and the direction that the strap wants to go, makes the pressure point almost impossible for the strap to move and thus it holds it firmly in place. When you are ready to fire, rewind the winch and the rope will be loose behind the cylinder, retract the cylinder and the kicker fires away if the top is connected to some type of material like surgical tubing or bungee cords to the rear of the system.
Is that clear enough, or should I draw some pictures?
My team, will not be using this method. We have adopted the 842 kicker style with the gate latch. Thanks 842.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
What 4 functions are you using for autonomous mode? darkpheonix General Forum 8 29-01-2008 23:38
What drivetrain style are you using? Mike Nawrot General Forum 32 27-01-2008 16:32
What tool are you using to make weight? EricH General Forum 40 27-02-2006 19:46
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
