the gyro
team 1307 has been working on the autonomous part of the code and wanted to know if anyone out there (and there must be someone) knows how the gyro works. we have never worked with a gyro before so bear with us if we need a bit of explaining. one of my team mates even went as far as to call the company that made the gyro and they deny all knowledge of the device.
thanks for any info Programmer Team 1307 |
Re: the gyro
How it works? Can't tell you that..
What it does for you? It measures how fast you are rotating. Mount it flat on your robot, and open it with a Gyro class, and it will measure how far you have rotated (angle) since you last reset. You can use this to calibrate a turn, basically saying turn until gyro is at x angle. |
Re: the gyro
It is a rate gyro. It tells you how fast the gyro is turning, in degrees per second.
It does NOT tell you how far you have turned - you must calculate that. For example, if it says it is turning at 15 degrees per second, and you see that it has done that for exactly three seconds, then you can calculate that it has turned 45 degrees. The "degrees per second" signal is in the form of an analog voltage. The voltage when it is standing still is 2.5 volts, and the voltage increases 10 mV per degree per second**. So 10 degrees per second clockwise gives you 2.5+0.1=2.6 volts. Counterclockwise 10 deg/sec would be 2.4 volts. Maximum reading is 250 degrees per second - turn any faster than that and the output does not increase. **This is from memory, please review the official specifications for the milliVolts per degree per second. Thanks. . |
Re: the gyro
Re: the gyro
Did you check the Sensor Manual? I found it very helpful last year when I was learning about gyros. Also, there (should) be a bit in the WPIlib documentation on the gyro class.
Re: the gyro
i was wondering about this same topic, is there a wiring diagram somewhere showing how to connect the gyro to the analog breakouts of the cRIO? we have never used a gyro before either and any information would be a big help.
#7
Re: the gyro
If you are using Labview, the gyro example code has a wiring diagram included. That code will give you current heading as well as yaw rate.
#8
Re: the gyro
thanks all! great info.
| how to attach the gyro sensor on the robot | dazero | Sensors | 1 | 02-03-2009 13:16 |
| The Gyro in Disabled Mode | eaglesfan10 | Programming | 2 | 09-02-2008 12:16 |
| Why does the gyro need the ADC? | cprogrammer | Programming | 16 | 27-10-2006 01:29 |
| Problems with the gyro | Conan | Programming | 7 | 06-02-2006 01:45 |
| Usage of the gyro | jon virgi | General Forum | 37 | 09-06-2003 11:57 |
