#9
Re: Holonomic issues
left side inverted:
forward command: all 4 wheels spinnning forward - goes forward ***this is what we get reverse command: all 4 wheels spinning reverse - goes backward ***This is what we get slide right command: wheels 1 & 4 spinning forward; wheels 2 & 3 spinning backward ***we get 1&2 spinning forward and 3&4 spinning backward - won't go anywhere slide left command: exact opposite of slide right ***we get 3&4 spinning forward and 1&2 spinning backward - won't go anywhere When we do not invert one side we get: forward command: all 4 wheels spinnning forward - won't go anywhere ***front wheel spinning forward back wheels spinning backward reverse command: all 4 wheels spinning reverse - won't go anywhere ***front wheel spinning backward back wheels spinning foreward slide right command: wheels 1 & 4 spinning forward; wheels 2 & 3 spinning backward ***this is what we get - slides right slide left command: exact opposite of slide right ***this is what we get - slides left I will check tonight when we get to the robot. We must have the left side of the robots PWM cables reversed on the digital side car. We are using the electronics board from last years robot and I know the PWM cables are bundled and zip tied. I also don't remember checking the digital side car end. We called out the PWM location by looking at the label we put on the PWM last year. Thanks for all the idease! I'll post the solution when we get it figured out, hopefuly tonight. |
| Holonomic drive angle? | dwodrich | NI LabVIEW | 17 | 05-02-2010 09:39 |
| Holonomic vs Mecanum Help!! | kSniper | Technical Discussion | 10 | 25-03-2008 16:57 |
| Holonomic Programming??? | sknkmeistermatt | Programming | 2 | 12-02-2008 15:47 |
| Holonomic... | Greg Perkins | Technical Discussion | 2 | 02-02-2005 11:59 |
| holonomic drives | Max Lobovsky | Technical Discussion | 5 | 10-03-2004 21:31 |
