Go to Post Even though others have had success, I will be honest, this method sort of creeps me out. - Joe Johnson [more]
Unread 02-02-2010, 08:34
EagleS!! EagleS!! is offline
FRC #3390 (Anatolian Eaglebots)
EagleS!! will become famous soon enoughEagleS!! will become famous soon enough
gyro problem
We put our gyro to the analog breakout. And when we open the driver station, indicator of gyro always turns around. When we move the robot, the indicator doesn't show a specific place. Do you have the same problem? Or what can we do?
Unread 02-02-2010, 10:48
Re: gyro problem
Check your wiring. Make sure the signal, power, and ground connections are going to the proper pins on input 1 of the Analog Breakout board. Make sure there is 12v power to the Analog Breakout, and that its green LED is lit.
Are you using C++? LabVIEW? Java?
Unread 02-02-2010, 12:23
Re: gyro problem
We are using LabVIEW
Unread 03-02-2010, 03:06
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: gyro problem
Are you moving your robot when you start the code? That would throw off the calibration making is spin all the time. Also, if it just isn't hooked up, it would probably just sit there, depending on the noise on the input.
Gyro problem Ushio Electrical 29 26-08-2009 14:41
Gyro Problem slade2000 Electrical 4 17-07-2009 18:02
gyro problem Guarana Programming 9 03-03-2008 15:48
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
