Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 02-02-2010, 08:48
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Analog Breakout Board
It appears we have two versions of the Analog Breakout stocked in the lab - Revision 4 and Revision 6. One is on red PWB and one is on a blue board. Does anyone know the difference between the two, and if using the older version is inadvisable or against FRC competition rules?
Unread 02-02-2010, 09:03
Re: Analog Breakout Board
They are both legal.
The new one Eric Van Wyk redesigned to be much more accurate that's all.
Unread 02-02-2010, 09:37
You can use them interchangeably.
Benefits of the Red one:
Its Red!
Higher maximum output current.
Benefits of the Blue one:
Its Blue!
Better accuracy and noise performance.
Unless you run into an issue with one, use whichever suits you better.
Unread 02-02-2010, 09:55
But I like red and blue equally! What am I to do!?
Thanks for the responses guys. We'll play around with both.
Unread 02-02-2010, 10:21
You could misinterpret the bumper cover rules and swap the two each match!
Unread 02-02-2010, 12:16
I like the alliance color swapping!
You also have two analog slots, one for each color.
Analog Breakout l.li Electrical 5 12-02-2010 15:56
Wiring a potentiometer to the Analog Breakout rsisk Electrical 6 19-01-2009 12:49
Analog Breakout for sale? DarKCroNo FRC Control System 1 05-01-2009 16:39
Wiring analog breakout? excel2474 Electrical 5 31-12-2008 17:30
5 Amp Fuses for Analog Breakout & Solenoid Breakout finman Electrical 3 10-12-2008 11:59
