Go to Post I think everyone just needs to chill out and realize what the real goal of FIRST is. - Koko Ed [more]
Unread 02-02-2010, 15:18
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: BDC-Comm Problems when setting jaguars up for CAN
Originally Posted by seannoseworthy View Post
And to confirm that your cables are properly made when you hold the RS-232 and the RJ-11 cable face up so the contacts are facing you, are they the same or reversed. If there the same there made correctly if not you must make the cable so that they appear the same.
I'm a little hesitant to jump in here, but I did read Sean's post and read it again after the most recent comments. I'm not sure any amount an analysis of it would have lead me to attempt the 180 rotation fix which kingofleet suggested. This is mostly because it doesn't seem clear how to hold the serial port when doing this comparison. If you held the 5 pin side of the serial port closest to you the results would be opposite from if you held the 4 pin side closest to you. Again, I may just be misunderstanding the suggestion though...
I think that it would be really helpful to document the correct sequence of wire colors from left to right entering the "net ioio" port of the jaguar when facing the jaguar from the front with a serial to CAN adapter plugged in to it. It could be that this information is already out there though and we missed it.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 02-02-2010, 16:00
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
In fact there is a color code in the documentation from TI. I would have thought it would be useful too. That is until the RJ11 to DB9 adapter kit I got had the wire colors on the RJ11 backward from what it is on the one TI used to make the instructions. Wasted a single insertion adapter. The pin numbers and a clear diagram of how to identify the pin numbers would be best.
-Joe
Where to find BDC-COMM utility? rrossbach Control System 5 31-07-2011 00:43
Trouble getting BDC-COMM to see the black Jaguar Randy Forgaard CAN 5 27-01-2010 09:14
Can ping CRIO and bridge, but DS shows no comm and no code Green2 FRC Control System 3 22-01-2010 23:55
Robot seems to be Disabled when using Jaguars Thxe C/C++ 2 11-02-2009 22:01
Camera power/comm problems disable the DSC rwood359 FRC Control System 2 03-02-2009 12:34
