Go to Post I guess my only option is to either stop picking on Dave or come up with an even better picture! Now, which one do you think I'll choose? - MissInformation [more]
Unread 02-02-2010, 15:21
Kyledoo Kyledoo is offline
FRC #2603
Kyledoo is an unknown quantity at this point
Re: Can't see any values on dashboard
Originally Posted by jhersh View Post
I recommend that you do modify it. You should customize it to show exactly what you want it to.
And how do you go about modifying it?
That's the file I'm talking about. All the commented out sections are examples. You don't need them once you remove the corresponding variable on the dashboard side.
Are you talking about modifying the robot program or the dashboard?
Those are digital inputs... it sounds like you've set up the encoder correctly.
Sounds straightforward. Now you just change the data type to the dashboard.
Start simple. Remove everything from the dashboard data on both the robot and on the dashboard. Add one INT32 to the robot code and to the dashboard... make sure that works, then add in any other data you want to display on the dashboard.
Where is the dashboard code? is this the dashboard class?
LabVIEW Video Tutorial: Customizing The FRC Dashboard To See Your Data LVMastery NI LabVIEW 0 10-02-2009 13:50
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
Bug? Can't seem to delete any of my PMs DanL CD Forum Support 2 15-12-2003 23:12
You can't see through an untouched starting wall of boxes Digo General Forum 31 11-01-2003 12:01
