Go to Post In FIRST, success = inspiration. - Daniel Brim [more]
Unread 02-02-2010, 14:59
Team1824 Team1824 is offline
FRC #1824
Team1824 is an unknown quantity at this point
motor controller error
Hey, programmer here (using Labview), we have been having some problems with the motor controllers on our robot. I have programmed a button to make a motor go forward. We know that the motor controller works because when we used it for the regular drive it turned red and green as it should. When I use the button to control a motor however the motor controller rapidly flashes red and orange when the button is not in use. When I push the button it flashes green red and orange. I know the code is right because I have used two separate versions, one from chief delphi and one from NI.
Can anyone please help???
Team 1824
Unread 02-02-2010, 15:32
Re: motor controller error
Originally Posted by Team1824 View Post
...I know the code is right...
If the code were right, it would be working.
Show us what you're doing. Oh, and tell us how things are wired so we can rule out electrical problems.
Unread 02-02-2010, 15:49
FRC #1824
okay here is the code. It is copied as best I can from NI's FIRST forum. The electronics is the same as last years, and that worked perfectly. We haven't had time to rework the electronics board yet.
ID:	8470  Click image for larger version
Team 1824
Unread 02-02-2010, 15:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
I see your problem.
You are opening and closing the motor in teleop.vi
This code does not contain the main loop; you must open the motor in Begin.vi, save it as a refnum, then get the refnum in Teleop.vi, use it, and leave it. If you want to be nice and close it, then get the refnum and close it in Finish.vi
Kettering Motorsports
Unread 02-02-2010, 16:36
Originally Posted by apalrd View Post
I see your problem.
You're actually opening and closing a lot of things in Teleop. That won't cause problems with some of them, but it will definitely break most of them.
The LabVIEW examples are typically set up as an Open, fed into a While, with a Close after the While. That's fine for a standalone example, but it isn't how the full robot code is structured. The robot project should have all the Opens put in the Begin vi, with each resulting reference fed into a registry Set vi. Everything inside the example's While should go in the Teleop vi, which you might think of as having an implied While around it. Use a registry Get in Teleop instead of another Open; you can see how that's done with the existing references. Put each Close from the example in the Finish vi, again using the existing code as a pattern.
Unread 08-02-2010, 14:55
FRC #1824
Yeah, opening everything in Begin.vi fixed everything. Thanks everyone.
Team 1824
Cheap motor controller dpeterson3 Electrical 15 17-06-2009 17:42
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
Motor Controller RoarRoar Motors 4 24-01-2008 21:32
purchase motor controller wkethman Electrical 7 09-01-2006 09:16
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
