Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 02-02-2010, 15:35
team3323 team3323 is offline
FRC #3323
team3323 is an unknown quantity at this point
how to set up 206 axis cam in labview
our team is in a hard spot we need to figure out how to setup the axis 206 cam in labview we dont know how but we need to figure it out any help would be awsome on how to get the software and the cam to work together
Unread 02-02-2010, 15:38
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: how to set up 206 axis cam in labview
You should first connect the cam to your computer via a crossover cable. Then, run the Axis Cam Setup Tool, it will setup the cam's IP address and passwords. This must be done or the camera driver will not be able to find the camera.
Then, you should plug the camera in to port 2 on the cRio.
The code necessary to track a target is shown in the default code. You should be able to use it without too much work. Reading over it will explain how the camera software works.
Kettering Motorsports
Unread 02-02-2010, 16:00
Everything you need to know is in the FRC Control System documentation. The http://www.usfirst.org/frccontrolsystem web page has links to each chapter. You must read chapters 1-3 in order to know how to use the control system effectively.
Unread 02-02-2010, 17:02
FRC #3323
well we got the cam working thats for all the help
how to set up 206 axis cam in labview team3323 General Forum 0 02-02-2010 15:23
Axis 206 cam frame rate yoavh360 Electrical 11 23-01-2010 21:45
AXIS 206 camera not working Wicked NI LabVIEW 3 21-01-2010 10:05
Axis Cam brightness in LabView Chath Maral Programming 3 07-02-2009 19:47
Anyone know how to get a live video feed from your axis cam? Jazonk FRC Control System 7 03-01-2009 20:08
