Go to Post I am all for high school sports, but as Dean continually preaches, we sometimes are not putting enough emphases in the right places. - Bill Beatty [more]
Unread 02-02-2010, 15:42
Re: Need help with tank drive
Originally Posted by zebrabots View Post
We put the code on via build under the build specifications tab. We have not tried to click run and see if it works.
Build only compiles the program on your local PC. You need to click Run as Startup to download it to the cRIO (both are required each time you change anything). Alternately, for debugging, you can click the run button in Robot Main.
Unread 02-02-2010, 16:35
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
ok thanks for the help we will be sure to try this as soon as we fix our program.
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
Problem with tank drive Mr. E NI LabVIEW 6 27-01-2009 16:59
Help with programing Tank Drive in Lab View zackcool123 NI LabVIEW 3 18-01-2009 19:49
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
