| Just the sight of you makes my vision system go haywire. |
| Thread Tools |
Rating:
Display Modes |
#76
Re: Robot Lifting
they were oriented vertically for the majority of the match, then dropped down at the end.
#77
Re: Robot Lifting
Some tips if you do try wings I learned from extremely simple and not very good prototypes:
1. With a robot roughly max width, you're just short of the max horizontal width on each side of the robot to fit in the 84 inch cylinder. So your forks would probably look like this: ------ ------------ ------ 2. Strong materials and fixed joints are key to cutting weight down. Once the forks are to the sides of your robot, an in bumper way to "lock" them helps, or a way to raise them ~5 degrees then lock to help ensure sliding doesn't happen. You can make the forks fall by gravity with a servo and "snap in" to place if you want. 3. Make sure your hanging mechanism works even if you only have one robot on one side. There are ways to do this. Last edited by Chris is me : 24-01-2010 at 17:18. |
#78
Re: Robot Lifting
what do people think about carabiners? well big ones! and what are peoples ideas for not getting stuck under the tunnel while trying to raise your robot up?
#79
Re: Robot Lifting
If you don't wanna get stuck under the tunnel you can do it strategically by lifting the back of your robot before your front or mechanically by keeping your front bot in a curved shape or a straight one, without bumps to get stuck under there. Yes, i know, "what about the bumpers?!"... make some mechanism that will fall over your bumper to give your bot's front curved or higher than the tunnel. for example: # #### ####### ########## ############ ############## ################ ###>DEVICE ######## ################## ################## ################## BBBBBBBBBBBBBBBBBBBBBB BBBBBBBBBBBBBBBBBBBBBB BBBBB>BUMPER BBBBBBBBB BBBBBBBBBBBBBBBBBBBBBB BBBBBBBBBBBBBBBBBBBBBB Consider this with your peers and Mentors... Good luck ![]() |
#80
Re: Robot Lifting
did anyone come up with an alternative to the CIM motors for some sort of winch climber? Were allready using all 5.
#81
Re: Robot Lifting
FPs with a stock gearbox can work.
#82
Re: Robot Lifting
FPs?
Not familiar. Do you have a pic/spec sheet? EDIT: Fisher Price? I found this on it: http://www.usfirst.org/uploadedFiles...or%20Curve.pdf Not sure how to read it though though (Im a programmer, leave me alone )Last edited by Brandon_L : 28-01-2010 at 19:07. |
#83
Re: Robot Lifting
Re: Robot Lifting
Re: Robot Lifting
Also, is the plan to attach to one verticle bar or two? I am invisioning a system that would use two but I think aligning them for attachment could be very tricky given the type of clamp. Any thoughts on this? |
#86
Re: Robot Lifting
I need help with a question the hook we are building, the hook is build to a pipe thats 84in 1/2 O.D. Now my question is,which is legal? Like 84 inches to the ground or 84 inches from the ground to the pipe?
#87
Re: Robot Lifting
Has anyone considered using a scissor lift mechanism to hang the robot?
#88
Re: Robot Lifting
We had considered it at first, but then a few of our more experienced mentors brought up the size and weight of the lift, and how it would cause problems with the balance of the robot while crossing humps.
#89
Re: Robot Lifting
yeah we considered it too but i think we are only going to use the scissor lift to lift the wench hook... just ideas. also what do people know about the cim shifter? is it possible to put a shifter in there without the second gear so it would be in neutral?
#90
Re: Robot Lifting
| 1070's 2007 Robot Lifting | AznPrincess3089 | Robot Showcase | 8 | 19-03-2007 19:37 |
| Team 192, Robot Lifting Teaser | Joobacca | Robot Showcase | 7 | 02-02-2007 17:46 |
| Lifting one vs. lifting two | jgannon | Rules/Strategy | 1 | 14-01-2007 17:37 |
| robot lifting | doomsdaytank | Rules/Strategy | 2 | 14-01-2003 16:41 |
| Lifting goals | patrickrd | Rules/Strategy | 6 | 17-01-2002 17:58 |
