Go to Post I'm pretty sure most teams would be OK with being somewhere between Division by Zero and Cheesy Poofs! ;) - Dennis Jenks [more]
Unread 05-03-2009, 22:35
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
Spike --- Labview
I'm having trouble figuring out how to program control into a spike that has a motor attached to it. How is this done?
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 06-03-2009, 20:24
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Re: Spike --- Labview
Use the Relay pallet under Digital Output. Then place constants that would go to "Set Relay" in a case structure, one in the True case and one is the False case. Wire the constants to the node on "Set Relay" and the boolean node on the case structure to a button. If you don't want a button, wire some other boolean input in instead.
Unread 02-02-2010, 17:12
bigdylmccoy's Avatar
bigdylmccoy bigdylmccoy is offline
FRC #3171
bigdylmccoy is an unknown quantity at this point
Already tried this and the spike relay is still giving us problems. We have 4 motors for our wheels and one more for our kicking mechanism. We seem to be having problems with coding our kicking mechanism. LabView keeps asking if we want to run it in Victor or Jaguar, which we don't, we want to run it through the Spike relay.
Please help.
Unread 02-02-2010, 19:29
Here's a generic example from last year.
You don't open a Motor when it gets used through a Spike. Motors are only if you use it with a Jaguar or Victor speed controller.
This year the opens get moved to Begin.vi and the Closes to Finish.vi.
The While forever loop is also not used in this year's program structure.
Some other examples over here.
Unread 16-02-2011, 21:41
TEAM-3871 TEAM-3871 is offline
FRC #3871
TEAM-3871 is an unknown quantity at this point
Hey I am having the same problem i am using a smiler looking code the only difference is i am using 2 button and its not working any ideas?
Unread 16-02-2011, 22:58
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
I am not entirely sure, but I believe you can program the spike through a DIO module using the Digital Output palette.
Unread 16-02-2011, 23:31
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
No, you definitely want to program it using the Relay VIs, as mentioned earlier. Using those VIs, you can set the relay to Forward, Reverse, or Off, rather than the -1 to 1 range you'd use for a Jaguar or Victor under PWM control. (Technically also there is also an On setting, although I'm not entirely clear what effect that would have on a motor and am disinclined to test it. I think it connects both outputs to power, which probably isn't going to do anything good.)
The page Mark linked to has some lovely examples.
TEAM-3871, can you explain a little further what you are doing with the two buttons? If you're just trying to have it go forward when button1 is pushed, reverse when button2 is pushed, and off when neither is pushed, you should be able to get there using either nested Cases or a couple of Select VIs. I'm attaching a picture of a random sample along those lines (pardon the excess white space - my machine is fighting me tonight).
Unread 17-02-2011, 10:34
The screenshot you attached has very low resolution and is very difficult to read.
I think this screenshot is similar to what you attached.
Unread 17-02-2011, 14:45
vhcook's Avatar
Reader of Things
AKA: Victoria
Sorry about that, I was using the wrong tool, with terrible results. Your screenshot is very similar to what I was trying to show, except I had Enums for Forward, Reverse, and Stop feeding into the selects, and the output went into a Relay Set VI.
spike jfrank Programming 4 16-02-2008 13:48
Banebot 64 to 1 on Spike? falconmaster Motors 7 15-01-2007 22:12
Spike Connection Gal Longin Control System 4 12-01-2005 13:59
solenoid/spike greencactus3 OCCRA Q&A 1 11-09-2004 09:54
spike great_one411 Electrical 2 06-02-2003 09:10
