Go to Post D is for Data, that's good enough for me... [munch munch munch munch] - Nemo [more]
Unread 02-02-2010, 17:26
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
What to do with sensors?
We have the sensors wired up, but we don't quite know what to do with them.
As in we can get the feedback properly, we just need ideas for what to do with it. I was thinking of something that used the accelerometer along with the joystick input to detect if the bot was being forcefully pushed, and that would be cool, but its only effective in competition if you get pushed directly forwards or backwards.
What else can we possibly do with them?
Unread 02-02-2010, 17:37
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Re: What to do with sensors?
Sensors are a a tool to solve a problem. If you don't know what to do with them, you most likely do not have a problem that needs to be solved with sensors. You should not attempt to solve non-existent problems just because the proposed solution is "cool".
Regardless, The gyro and accelerometer can be used to determine the robot angle, angular rate, velocity and position, which can be useful for some robots, particularly during autonomous. The gyro can also detect gravitational acceleration and it's direction, thus enabling you to detect how much of an incline your robot is at.
What rugged sensors do you use? Jon236 Control System 1 16-05-2007 07:30
What sensors do you use? StevenB Programming 18 06-04-2006 23:33
POLL: What sensors do you use Rickertsen2 Technical Discussion 10 28-11-2004 14:46
IR sensors: dealing with reflections? gnormhurst Programming 3 08-03-2004 20:04
Fun with sensors Team852 Technical Discussion 7 06-01-2003 00:07
