Go to Post FRC for a four year student is a marathon disguises as four sprints. I'd much rather win the marathon than a sprint. - Ian Curtis [more]
View Poll Results: How many wheels are used in your drive train?
1 Wheel (Must post pics ) 1 0.54%
2 Wheels 0 0%
3 Wheels 1 0.54%
4 Wheels 82 44.32%
5 Wheels 2 1.08%
6 Wheels 39 21.08%
Tank treads 9 4.86%
Other 51 27.57%
Voters: 185. You may not vote on this poll
Unread 02-02-2010, 18:07
Chris is me's Avatar
AKA: Pinecone
Re: Poll:2010 How many wheel drive are you using?
8 wheel drive is going to be common enough that I would highly recommend you add it to the poll. 2791 is doing 8 wheel.
Unread 02-02-2010, 18:32
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
1771 is going with 8wd
Mentor 2415
Unread 02-02-2010, 19:11
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Team #2849, Ursa Major, (and I) are going with 12 Wheel Drive.
Why? It seemed like a good idea at the time ;-)
Honestly, because I am paranoid of getting stuck on those bumps and 12WD seemed like a good way to prevent that from happening.
Would 8WD been enough? Perhaps, but with each new crossing the bump video that gets uploaded to youtube, I grow more convinced that 12WD has its advantages...
Joe J.
Team #88, TJ2
Unread 02-02-2010, 19:23
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Joe J.
Yeah I think a lot of teams will be going with 8wd (we are). The reason 488's robot tipped like that (like many 6wd drive robots will) is because a lot of their weight is distributed in the back. If you can keep your weight balanced correctly, even with 8wd drive, you wouldn't flop like that. (We watched our robot cross the bump on CAD, but haven't gotten the chance to test it in real life yet).
Unread 02-02-2010, 19:28
AKA: Pinecone
Be aware that with a centered CoG, you will still have a pretty spectacular fall over the bump due to momentum unless you take it somewhat slowly. But not too slowly that you get defended easily. Driving is hard...
8wd shouldn't be high centering diagonally too much. 488's video basically demonstrated you have to be completely sideways to high center.
Andrew Schuetze's Avatar
Happy Birthday! Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
The low clearance of a standard chassis with 8 wheels scares me now that I see it getting high centered on the hump sideways. That just seems to be another plus for the using the KOP stand-offs. The big negative is raising one's CG.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 03-02-2010, 14:02
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Joe J.
I agree, except in this case I think less is more.
We are going with 4 wheels this year after a demonstration showing the dynamics is much more stable than 8 wheels could ever achieve.
Most 8 wheel drives are counting on very low center of gravity, except I don't think you can count on that if you want to do any sort of hanging, or if the CG is anywhere near 10-12 inches off the ground.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 03-02-2010, 15:32
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Ken Leung View Post
<snip>
<snip>
Hey Ken,
Long time, no see (though more my fault than yours).
But... ...there you go again making blanket statements that may come back to haunt you.
Of course it is possible to make an 8WD or even a 12WD that is less stable than a 4WD robot going over the bump, I would just caution you about making statements that beg to be proven wrong.
"There are no black swans" only requires 1 observation to be wrong. "Black swans are rare" is a safer statement that is less likely to put egg on the face of the speaker.
Joe J.
Team #88, TJ2
Unread 03-02-2010, 16:34
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Team 148's robot will have 14 wheels in the drivetrain.
Seriously.
Unread 04-02-2010, 12:02
AKA: Dr. Joe
FRC #0088 (TJ2)
Seriously.
MAN! I thought I was doing so well with 12WD.
Ah well. If you are going to be beat, you may as well get beat by the best. No shame in that. Well played JVN, well played...
However... ...One day, I am going to recover my FIRST Kingdom and I will rebuild my FIRST Design House and my FIRST Machine Shop... ...I will once again join the ranks of FIRST SupePowers, as it was in days of yore... ...When that day comes, you can only only IMAGINE how high N will be in my N Wheel Drive creations! The digits shall reach from sea to shining sea. Muhahahahahaaaaaaa!!!!*
Joe J.
*Spoken in an evil voice somewhat akin to Mojo Jojo's
Team #88, TJ2
Unread 04-02-2010, 12:09
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Seriously.
To those who don't know how this is possible, take a look at 703's drivetrain from 2007: http://www.chiefdelphi.com/media/photos/26312
Now just take that, replace the polycarb sides with the traditional stamped aluminum sheet (IFI style), paint it black with red anodized wheels and I bet you are close to what it will look like. I'm sure it will be another stunner just like the 148 bots have been since '07.
I am excited to see what team IFI pumps out this year, especially 148 after this news.
Unread 04-02-2010, 12:27
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
8 Wheels total. 6" dia. Wide chassis. Corner wheels on the ground. Plaction in front, Omni's in back. Middle 4 wheels elevated 2". All powered. Center of Gravity around 7".
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 04-02-2010, 16:07
ParkerF's Avatar
ParkerF ParkerF is online now
Learn it. Teach it. Spread it.
AKA: Parker Francis
FRC #0118
ParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond repute
Not quite...
-Parker
Team 148 Alumnus - '07-'11
Team 3481 College Mentor - '12-'14
Team 118 Mentor - '17-Present
Unread 04-02-2010, 21:11
Gone Fishin'
Originally Posted by francistexas View Post
Not quite...
-Parker
14 wheel swerve?!?!
Unread 04-02-2010, 21:18
AKA: Dr. Joe
FRC #0088 (TJ2)
14 wheel swerve?!?!
Yes it is so obvious now that you say that. 8WD fore/aft + 6WD left/right.
It's BRILLIANT!
...or...
it is a whole lot of bother not that much gain...
The truth will out.
Joe J.
Team #88, TJ2
How many motors are you using on this years robot? VanMan Motors 47 02-02-2009 15:48
how many of you are using a shooter or dump bot? 647techangel Rules/Strategy 4 20-01-2009 22:31
How many Joysticks are you using? MiniNerd24 Control System 31 25-02-2008 07:20
poll: how many teams are using ramps? Aaron Harvey Rules/Strategy 4 26-01-2007 01:26
How many motors are you using to drive? Joseph F Motors 18 16-10-2002 21:24
