Go to Post I, for one, refused to be railroaded down this train of thought so easily! Geeze, one lousy game hint just builds up steam for any old picture to come through and go two pages in a matter of hours. - Billfred [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 02-02-2010, 18:31
Darth Pbal's Avatar
Darth Pbal Darth Pbal is offline
AKA: Paul Ronquillo
FRC #2375 (Biohazards)
Darth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud of
Need Help With Deploying Code
We need to figure out when to put the cRIO into safe mode
Do we do it when running temporary code?
How about when we want to deploy code to the robot?
What are the steps for deploying code to the robot?
-Go Team 2375!
Darth Pbal
Unread 02-02-2010, 19:06
Re: Need Help With Deploying Code
Under normal conditions never put the cRIO into Safe Mode. If you have a dead brick-like cRIO, then you might do it, but ask someone first.
To download code start at the LabVIEW Project Explorer window.
  • At the bottom under "Build Specifications" right-click on the file listed there. and select "Build"
  • After that's done right-click and select "Run as startup"
Unread 02-02-2010, 19:20
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You should not be putting the Crio in safe mode. That is a recovery mode when you have made a major, major mistake (or the Crio has made a major, major mistake) and you're going to have to reformat it. Very similar to why you'd be starting your computer in safemode.
Section 2.8.1 of the 2010 Getting Started manual describes how to run code on the CRIO. No where does it suggest safemode.
It also suggests you review the Labview Robotics Programming guide if you want to more about deploying software to the Crio. It states you can go to National Instrument's website and search for it to find it. I put the name into google and found it on the first try.
In addition, you should search on chief delphi for "deploy code to crio". You will find dozens of results. Some of which guide you step by step for what you're looking for.
Edit: Saw that Mark answered the question. Mark - you have the patience of a saint. I'm nearly to the point where "read the manual" is my first response to every question .
Need Help With Deploying Code Darth Pbal National Instruments LabVIEW and Data Acquisition 0 02-02-2010 13:19
Having trouble with Deploying code Hatefulhippo Programming 2 15-02-2009 14:02
Need help with code CaseyKasem_1251 Programming 3 18-02-2006 09:39
Need help with code. hawk_11 Programming 6 06-02-2005 13:56
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
