Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 02-02-2010, 18:58
rhf323's Avatar
rhf323 rhf323 is offline
El Capiton
AKA: Ryan Fuller
FRC #1458 (Red Tie Robotics)
rhf323 is an unknown quantity at this point
The Av8r 01 Joystick
We got the av8r 01 Joystick and we cant get the mini joystick on top of it to work or to be recognized in any way
There is a link below
http://qualitydealsdirect.com/fastlo...issglobal1.jpg
Any ideas how to get it to work?
Unread 02-02-2010, 18:59
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: The Av8r 01 Joystick
The mini joystick on top is the POV hat. Unless it is mapped to buttons or axis in code, you do not have access to it. If you can read everything else, then that is your problem.
Kettering Motorsports
Unread 02-02-2010, 19:11
rhf323's Avatar
El Capiton
AKA: Ryan Fuller
OK thanks do you know how we could get the mode switch on the joystick working?
Unread 02-02-2010, 19:14
apalrd's Avatar
More Torque!
VRC #3333
Does the mode switch on the joystick show up as a button or does it change the mode of the joystick at the joystick itself? To my knowledge, there is also no way to use the mode switch. We have a Logitech gamepad with a mode switch, and we can't use it.
Problem with the joystick Asmos NI LabVIEW 5 23-01-2009 09:40
Programming the joystick trigger... pudgeball C/C++ 4 10-01-2009 10:25
Reducing the sentivity of the joystick in easyC Pro Neurovirus Programming 9 19-01-2008 09:30
The best joystick? Japper General Forum 18 16-01-2007 17:15
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
