Go to Post ...I tried to pump it up to the 47 inches. I stopped around 42 inches, than tried getting it through a 36" door. It got stuck, I proceeded to dropkick the thing in front of my team and a girl I had gone out with the previous Fri. It didn't move, I hit the floor. Ouch, my pride. - ChrisMcK2186 [more]
Unread 02-02-2010, 19:44
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Power distribution
Hi, we want to know if it´s possible to use this kind of plugs that you see in the photo. could we use it?
We have all the electronic system in a drawer, so if we want to take off the drawer of the robot, we are going to need disconnect the power distribution of everything.
thanks
Team 2576 -Corazón de Chileno-
<-Chilean Heart->
Unread 02-02-2010, 20:06
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Power distribution
What are the electrical ratings on them?
If they are rated for 12+ Volts DC, then you're fine. Must be DC rated to at least the amps you are using them for. If it's for CIM's, thats at least 40 amps (breaker rating), preferably more.
You put your electronics in a drawer? I would generally put electronics on perforated aluminum and have no connectors between each end, except possibly spade terminals on motors with built-in leads (CIM's, the old Globe motors)
If those are the connectors I think they are, they are rated for 125VAC and are polarized with a center-pin ground. If they aren't, they are probably AC rated. I don't know what connector they are, so I am thinking of a connector I used to use in stage lighting (3-pin with offset center ground).
If you need to disconnect things, look into simple spade terminals. Keep everything labeled, and you will have no problems.
Kettering Motorsports
Unread 02-02-2010, 22:40
DonRotolo's Avatar
Back to humble
FRC #0832
In my opinion, those would be OK. But please understand that my opinion is worthless at any competition.
You may consider using a connector that is a bit more capable of handling high amounts of electrical current (Amps), especially for motors (CIM, Fisher Price) and the compressor, because the loss in that connector may really hurt your ability to drive well.
Go to an electrician's supply store and explain what you are trying to do (quick-disconnect for 40+ Amp circuits, 12 Volts DC, light & inexpensive) and they should be able to help you.
If you can get them, Anderson Powerpoles come in 45 Amp rating (they are a LOT smaller than the battery connector), we use them everywhere.
Unread 03-02-2010, 00:33
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
At the risk of giving away one of our secrets, I'll second the reccommendation for the smaller Anderson Powerpoles. The PP45 size is perefect for what you want to do and can be arranged in endless number of contacts and configurations.
They are secure in their connection and if you want to really ensure they don't inadvertently come apart, they make locking devices.
They also come in many colors (besides red and black) if you want to color code things.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 03-02-2010, 08:31
Those appear to be pro lighting (stage) connectors. If they are, then yes, they would be capable of the currents and voltage on the robot. However, they are large and heavy as they are intended to carry large loads and high currents (as well as high temperatures). From the standpoint of this year's game, the vibrations encountered would put some stress on the connections to the pins in these connectors. You will also need to insure that the connectors will not separate and expose the pins during operation. There are other, more suitable connectors but I am not sure they are available in your country.
Unread 03-02-2010, 23:22
DonRotolo's Avatar
Back to humble
FRC #0832
Here is a good source for the powerpoles (and crimpers) in the USA
Unread 03-02-2010, 23:31
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Best advice: Any power connectors you use that aren't included in the KoP should be accompanied by a data sheet showing that they are rated for the appropriate power levels.
Power distribution board does not give power to access point bitsoglass NI LabVIEW 3 17-02-2009 12:07
Power Distribution Board BrandonD-1528 Electrical 2 31-01-2009 11:30
New Power Distribution jsmith234 Electrical 6 03-02-2007 15:05
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
