Go to Post Have you hugged a Martian today? (Dave, don't answer that.) - Billfred [more]
Unread 02-02-2010, 20:07
2522BanMonkey's Avatar
2522BanMonkey 2522BanMonkey is offline
no
FRC #2522 (Royal Robotics)
Team Role: Electrical
2522BanMonkey is an unknown quantity at this point
Plugging Solenoid
Where do we wire the solenoid? Thanks for the help.
Unread 02-02-2010, 20:09
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Plugging Solenoid
cRio solenoid module, slot 7 or 8. If you run out of spaces there, you can use Spike relays.
I encourage you to read the control system manual. Your question is answered there.
Kettering Motorsports
Unread 02-02-2010, 20:13
no
how do i wire the solenoid to the pins
Unread 02-02-2010, 20:46
apalrd's Avatar
More Torque!
VRC #3333
There should be two wires, red and black. Red goes to +, black goes to -. Take the 2-pin cables from the kit (like the 3-pin PWM cables but with only 2 pins) and connect them from the solenoid to the solenoid breakout board on the cRio. Depending on what connectors your solenoid has, you might have to cut the 2-pin cable in half and solder it to the leads of your solenoid.
Unread 02-02-2010, 21:41
no
TY that helped alot we are noob electricians
SJS Electrical Squad
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
single solenoid seanl Pneumatics 4 18-02-2007 02:32
Programming a Solenoid Brigander Pneumatics 4 17-02-2007 14:06
Solenoid Help Brigander Programming 2 14-02-2007 17:13
solenoid/spike greencactus3 OCCRA Q&A 1 11-09-2004 09:54
