Go to Post Flattery will get you everywhere. - nuggetsyl [more]
Unread 30-01-2010, 17:50
aybose aybose is offline
FTC #2485
aybose is an unknown quantity at this point
Cannot connect to cRIO
I finished configuring wireless and was able to navigate to both 10.xx.yy.1 and 10.xx.yy.4. At this point, I went back to download the Java code from Netbeans and the build failed when it tried to connect to 10.xx.yy.2, the cRIO. I was able to ping the router and the bridge, but not the cRIO. When I connected the Classmate to the cRIO directly and tried to ping 10.xx.y.2, it said "Unreachable Host". I went in to try to reimage the cRIO and it was not finding the cRIO. I went into the Driver Station and re-entered our team number, to see if that would reset the ip properly, but it still did not work. I changed the subnet mask from 255.0.0.0 to 255.255.255.0, but still nothing. I set the ip address back to 10.xx.y.10 (the driver station changed it to 10.xx.y.5), but still nothing. I'm totally at a loss for the cause of the problem, and any help would be much appreciated
Unread 02-02-2010, 18:44
FTC #2485
Re: Cannot connect to cRIO
Any ideas?????
Unread 02-02-2010, 20:24
James Dempsey James Dempsey is offline
Overtired Programmer
AKA: Rooster Cogburn
FRC #1559 (Devil Tech)
James Dempsey is an unknown quantity at this point
This can possibly can be caused by mismatching versions of the image on the cRIO and the FRC plugin used for Java development. We ran into this problem very early into the season and fixed it by reinstalling the entire FRC provided content as well as running the latest installer, and downloading the latest imaging version for the cRIO and re-imaging it. Sorry if you have already tried this but I hope this can help.
James D
Unread 02-02-2010, 22:20
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
This is a networking issue. First see if you can connect to it from a command line:
- ping 10.10.1.2
- ftp 10.10.1.2 (leave the user and password blank)
If both of those work then check that the windows firewall is turned
off.
If ping and ftp don't work, you can double check the networking setup
documentation, or try asking questions in a more general (non-Java) forum.
Good luck!
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
I/O Board Cannot Connect Haragorn FRC Control System 2 14-01-2010 13:50
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 09-03-2009 22:10
Cannot connect to the Real-time target Mr. E FRC Control System 13 02-02-2009 20:47
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
