Go to Post As a rookie team member at my first event, i had a great time, the little glitches meaning nothing. - Gluedtothefloor [more]
Unread 02-02-2010, 19:43
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
is there a way to invert a motor live?
is there a way? i want to invert a motor in a four wheel drive
Unread 02-02-2010, 20:09
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Re: is there a way to invert a motor live?
you could hook up a multiply the value of the motor by 1, or -1 using a select statement (or case structure) that is decided by a control on the front panel, and button on a physical controller, or even using the simulated io's on the dashboard.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 02-02-2010, 20:25
the thing is im using a 4 wheel drive theres no way to multiply or such
Unread 02-02-2010, 20:49
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
If you mean simply invert a motor direction permanently, you can do that at the Open 4 Motor VI. Simply change the boolean constant of the motor in question.
If you mean change it while running the code in real time, you can do that too. What you need to do is replace the boolean constant on Open 4 Motor VI with a boolean indicator and then toggle the boolean indicator on the front panel.
Unread 02-02-2010, 20:55
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The motor open command only occurs once. You cannot change the boolean real time as the motor open should be in the begin VI that is only run once.
One way to do it is to run your joystick wire through a true-false case statement and multiply it by -1 (or use the negate icon in the math menu) when you push a button.
Is there a Way To refrence a true false statement Must Be Drama NI LabVIEW 15 02-02-2010 01:08
Invert camera image? mcb NI LabVIEW 2 21-02-2009 13:23
Is there a way to display Cmaer Live footage? Tottanka FRC Control System 0 12-12-2008 11:21
Is there a way to read your Team Colour during autonomous mode? Firestorm Programming 2 19-02-2005 18:57
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
