Go to Post It definitely looked like a penalty, but in FRC if it looks like a penalty and smells like a penalty, well, unfortunately it might not be. - Basel A [more]
Unread 02-02-2010, 16:52
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
Problems with RefNum Registry get vi
We have none of the wires coming from it... So it is messing up our whole program.
Does anyone have a suggestion on what we should do?
Has this happened to anyone?
Thanks Zebrabots Programmer Ty Adley
Unread 02-02-2010, 17:21
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Re: Problems with RefNum Registry get vi
What do you mean you don't have any of the wires coming from it?
You have to open something (joystick, drive, etc.) then put the wire from that into a refnum registry set. then use the refnum with a refnum registry get vi to use it.
Screenshots of your problem would help me out tremendously.
EDIT: Nick Tahoe's is an amazing restaurant btw, assuming the rochester you're from is Rochester, NY.
Unread 02-02-2010, 17:32
FRC #2909
It's Rochester Indiana. The problem is that the vi itself has no wires input options coming from it. There are not inputs to the vi for data. I think one of the other programmers deleted the code for the vi itself.
Unread 02-02-2010, 22:16
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
If you mean that there's no way to wire into it, or out of it, then here's a possible fix ...
Open the problem VI, on it's front-panel, right click the VI's icon in the upper right and select "Show Terminals". If none of the little squares are colored in, then there are no terminals (they disappear if you delete the original source control/indicator).
To connect something to an output/input "pipe", then simply hover over the little square that you want it to come in/out, click it, then click on the item you want to link to it.
Hope that helps.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Get Image problems Igor1201 NI LabVIEW 1 31-01-2010 00:11
Refnum Defining Pausert NI LabVIEW 15 21-01-2010 21:45
refnum registry location Wendy Holladay NI LabVIEW 1 17-01-2010 22:11
Registry Access in delphi collins Programming 2 04-02-2005 03:08
AIM Registry Back Up archiver 2000 0 23-06-2002 23:09
