Go to Post "The only constant is change" is a hint that probably applies to every season of FIRST. - Chris is me [more]
Unread 02-02-2010, 21:18
Darkknight512 Darkknight512 is offline
Programmer/Electronics
FRC #3375 (North Stars)
Darkknight512 is on a distinguished road
How to hook up Nason pressure switch
How do I hook up the pressure switch? Do I cut a PWM cable and connect the 2 terminals on the switch together then plug the cable into the digital IO negative pin?
Just doesn't seem right to me so I want to make sure.
Unread 02-02-2010, 21:51
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: How to hook up Nason pressure switch
The pressure switch is a digital "On / Off" switch. Really, it's just a mechanical contact internally that completes a circuit, but since it's only two states are either "On" or "Off" we (my team) call it digital.
I'm not sure what you mean by connecting the two terminals together.
You do attach a wire to each and then run them back to the digital I/O on your bot.
The third page of the pneumatics manual explains this in slightly more detail.
Unread 02-02-2010, 22:09
So one side goes to signal and one to ground or one side to positive and one to ground?
Unread 02-02-2010, 22:16
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
I would make sure you are correct before powering on the robot, we wired ours incorrectly and the pwm became very hot, we could not drive our robot until we removed it from the Digital I/O and at that point the Sidecar was also hot.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 02-02-2010, 22:23
DonRotolo's Avatar
Back to humble
FRC #0832
One side goes to signal, for certain, otherwise there'd be nothing for the cRio to 'see'.
Traditionally the other side is connected to ground.
Unread 02-02-2010, 22:24
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
You connect the signal (white) and ground (black). You can just put a piece of electrical tape on the positive wire because it is not needed.
Unread 02-02-2010, 22:32
Thank you, hopefully I get this working tomorrow.
Unread 03-02-2010, 08:44
You must put insulation on the center/red/positive wire.
Unread 04-02-2010, 18:45
I can't seem to get the compressor to turn on with the relay. I put in the code (C++)
#include "WPILib.h"
#include "vxWorks.h"
#include "Vision/AxisCamera2010.h"
#include "PCVideoServer.h"
#include "Compressor.h"
#include "Utility.h"
#include "DriverStationLCD.h"
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick;
public:
RobotDemo(void):
myRobot(1, 2), // these must be initialized in the same order
stick(1) // as they are declared above.
GetWatchdog().SetExpiration(1.0);
GetWatchdog().SetEnabled(false);
AxisCamera &camera = AxisCamera::getInstance();
camera.writeResolution(k640x480);
camera.writeBrightness(10);
camera.writeCompression(25);
Compressor *airc = new Compressor (1,1);
airc->Start();
void Autonomous(void)
myRobot.Drive(0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.Drive(0.0, 0.0); // stop robot
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
while (IsOperatorControl())
GetWatchdog().Feed();
myRobot.ArcadeDrive(stick);
Wait(0.005); // wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Unread 04-02-2010, 22:13
Describe how you have the switch and compressor wired. We might notice something that doesn't match the code you posted.
Unread 05-02-2010, 00:40
Tom Line's Avatar
Also, manually fire up the compressor and take your system up to pressure. Have a digital multimeter across the ears of the pressure switch and measure resistance to ensure that it is, indeed, actuating.
Unread 06-02-2010, 20:52
I just got this and the solenoids to work.
Thanks for your help anyways.
Unread 09-02-2010, 01:09
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
When hooking it up, as far as I can understand it goes in a digital I/O port on the digital sidecar, but is there a difference as to which wire (signal or ground) you connect to which terminal (NC or C) ?
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Unread 09-02-2010, 07:43
Craig,
It is a simple switch so there is no polarity issues. There is no active circuitry inside.
Unread 09-02-2010, 08:00
Electrically it makes no difference.
If you want to be a stickler for convention, however, the "C" stands for Common and ought to be wired to ground. The "NC" or Normally Closed contact ought to be wired to the signal input pin.
nason pressure switch wire holty531 Pneumatics 3 31-01-2008 22:18
Nason Pressure Switch? DPPT1717 Pneumatics 10 09-01-2007 22:31
No value in digital ins using NASON pressure switch. Ari Allyn-Feuer Programming 1 18-02-2006 01:18
Urgent need for Nason pressure switch!! PLEASE HELP! haverfordfords Pneumatics 12 18-02-2005 02:04
Nason pressure switches JP_1163 Pneumatics 11 03-03-2003 23:03
