Go to Post Now I'm having visions of thousands of balloons and a grumpy old man. Oh, and a talking dog. No talking dogs on the field. Grumpy old men are ok - sometimes. - JaneYoung [more]
Unread 02-02-2010, 22:43
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Robot Lifting
Originally Posted by JHSmentor View Post
how are you making the clamp engage the tubing? in the picture above, the actual weight of the clamp fingers causes it to initiall close around the cylinder. then as it is hoisted off of the cround the clamp sqeezes tighter - caused by the additional weight of the cyclinder itself. But - gravity is doing the work initially. For the robot, this mechanism would be verticle so you would have to initially get the clamp to squeeze a little around the bar before activating the winch and fully tightening it. I can think of some ways to make this happen - just curious if you have come up with something.
Also, is the plan to attach to one verticle bar or two? I am invisioning a system that would use two but I think aligning them for attachment could be very tricky given the type of clamp. Any thoughts on this?
One method we considered was using a lead screw to attach to the pole. We have found, though, that the robot weight is enough to maintain a positive grip. We aren't done enough to drive yet, but we will be using V-type guides to align the gripper. Plus the gripper opens quite wide until engagement.
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
