Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Unread 02-02-2010, 22:50
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Picking Two other Robots off the ground
Originally Posted by Lil' Lavery View Post
That's assuming that the other robots are designed to hang from the bar. That's a pretty big assumption to be making if those 8 points are a major part of your strategy.
It is an assumption, but it being that big of an assumption is arguable. Yes there are designs being implemented to use the four supporting bars, and other means, to suspend the robot but the large majority will be hanging from the bar as originally intended, and unless your robot design prevents this it should be relatively simple to implement.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Formula for Lifting Two Other Robots Jacob Paikoff General Forum 2 10-01-2010 00:09
Average height off the ground??? KcTechTeacher Technical Discussion 11 10-01-2007 22:23
Who is picking up from ground? sanddrag Rules/Strategy 15 10-02-2006 09:55
Emergency: PID with Wheels Off the Ground Rick TYler Programming 9 07-02-2006 11:37
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
