Go to Post the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 02-02-2010, 22:25
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
How to get camera to move?
For some reason, I can't find this. What methods are used to make the camera servos move? What are the method names and arguments? Is there anywhere I can find them? Thanks guys!
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 02-02-2010, 22:55
Re: How to get camera to move?
You speak of "methods" and "arguments", so I will assume you're using C++. The way to control a Servo is with the Servo class.
Look at page 64 of the C Programming Guide for FRC.pdf file. It is installed by default in the C:\windriver\docs\extensions\FRC directory.
Unread 02-02-2010, 22:58
The default code this year does not use servos to move the camera. You'll find the FRC Vision Whitepaper helpful in understanding how the vision software works.
I don't think the circular target lends itself well to using the servos to search for the target.
Unread 03-02-2010, 23:17
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
If using Java look up the set methods in the Servo class in the Java docs.
www.sharkattack744.com
Camera - how to get out of B&W? pgaston Technical Discussion 9 19-12-2008 09:00
Off-Season Challenge - I Like to Move It, Move It! Kevin Thorp 3D Animation and Competition 11 03-11-2008 16:04
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
how does your robot move? gondorf Technical Discussion 9 16-01-2006 16:36
