Go to Post We want your $0.02!!!! (and for that matter, if anyone can loan me $1.49 for a few donuts....) - dlavery [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 14-01-2009, 20:06
morg102 morg102 is offline
1141 Programer
AKA: Morgan S
FRC #1141 (Mega Watts)
morg102 is an unknown quantity at this point
Question Buttons on a Attack 3 Joystick useing LABView
I have found many post's but no answers on this subject.
Please dont give me outside links or links to other topics here
I would just like to know how to spesifiy witch button on the joystick i am useing.
Thanks,
1141
Unread 14-01-2009, 20:27
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Re: Buttons on a Attack 3 Joystick useing LABView
Right click on the "Buttons" cluster -- Go to the "Cluster Pallette -- Click unbundle -- wire that to the Button out -- wire to the button you want.
Hope that helps.
Unread 14-01-2009, 20:41
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Here's a bit more of a visual in case you're using the basic framework (Pretty much what DHR2o said):
Go to your palette and go to "WPI Robotics Library" > "DriverStation" > "Joystick" and add a "Get.vi" .. hook it up to the connector shown below:
Go to your palette and go to "Programming" > "Cluster, Class & Variant" and add an "Unbundle by name". Hook it up to the pink output of the get VI as shown below:
Now from the cluster outputs you have access to all of the buttons.
Good luck!
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 15-01-2009, 00:08
1141 Programer
AKA: Morgan S
Smile Re: Buttons on a Attack 3 Joystick useing LABView
Thanks, me and the other programer found a salution but this is alot better.
Unread 19-01-2009, 15:55
CPUGenuis's Avatar
CPUGenuis CPUGenuis is offline
AKA: Matthew Marshall
FRC #1208 (Metool Brigade)
CPUGenuis is an unknown quantity at this point
wait, what's the difference between using get and get raw for the buttons?
it's electrical's fault. end of story.
Unread 19-01-2009, 16:14
TotalChaos's Avatar
AKA: Austin
As far as the buttons go, nothing. The only difference I know of is the joystick axis output ranges from like -30000 something to +30000 something in increments of 256 or 512 or something around there...
- Austin
Unread 19-01-2009, 16:29
CPUGenuis's Avatar
lol, k. thanks.
Unread 30-01-2009, 17:16
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Post Re: Buttons on a Attack 3 Joystick useing LABView
- Austin
The joystick ranges from -1 to 0 to 1. If it is scaled to 127 (which it is set to by default) then the joystick ranges from -127 to 0 to 127. Which gives you a more finer control over a motor.
Unread 30-01-2009, 17:19
TotalChaos's Avatar
AKA: Austin
Ah, that's right... When I wrote that I was thinking about the preseason when we had a joystick hooked up to the computer directly and got input through the computer... My bad.
- Austin
Unread 08-02-2009, 12:53
mcristina444 mcristina444 is offline
FRC #2078 (Robotic Ooze)
mcristina444 is an unknown quantity at this point
what is the joystick axis output?? it is really -1 to 1??? or is it 0 to 256 or -158 to 158
Unread 08-02-2009, 13:04
-1 to 1. If you have a running system, don't forget that in LV you can open the panel and watch the values as they flow through. Many times that is a good way to understand the values being sent.
Greg McKaskle
Unread 02-02-2010, 15:35
Mohit Mohit is offline
FRC #3053
Mohit is an unknown quantity at this point
I want to program in a way that when i press the trigger the motor works at half speed...
I don't know how to do it.. I did a little bit of the steps that were mentioned above and it really didn't help. So can you tell me how to do it??
If you can provide pictures with that I would really appreciate..
Thank you..
Mohit
Unread 02-02-2010, 16:02
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Create a case structure. Wire the button input to the case structure's "?" node. Then make the "True" case have a 0.5 constant in it. Make the "False" case have a 0 constant in it. Wire both the constants out of the case structure to the Set Motor VI. Voila!
Unread 02-02-2010, 21:42
FRC #3053
Thank you for the help..
I'll let you know if it works once I get to school tommorow and start working on it..
Unread 02-02-2010, 23:28
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Here's a shot of something that doesn't do exactly what you want, but it's close and easily modifyable ... our trigger overrides the throttle and sets it to full speed.
In the pic, the case structure shows the FALSE case, where the throttle goes straight thru, but when button 1 is pressed, the TRUE case has a hard constant 1.0 wired up into the throttle output of that case structure, ignoring the actual joystick throttle until the button is released.
In your case, you'd wanna' wire up a 0.5 constant to it, if you want half-speed.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
How do you program joystick buttons in LabVIEW? darkpheonix NI LabVIEW 10 13-04-2014 10:20
Joystick buttons access byteit101 C/C++ 3 14-01-2009 19:38
buttons in LabView Pneumaticsman NI LabVIEW 4 12-01-2009 18:14
Buttons to Pins on Joystick yarb65 Electrical 1 24-08-2007 20:39
Assigning Joystick buttons.... archiver 2001 5 24-06-2002 00:59
