Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
  #76   Spotlight this post!
Unread 02-02-2010, 22:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Fasteners extending outside the FRAME PERIMETER
I still can't understand why teams don't just build their robots an inch smaller than the sizing box. All this debate over bolt heads sticking out is just silly.
The rule should read like this:
"We're bringing a box with these dimensions. You better be sure ALL of your robot fits in it"
  #77   Spotlight this post!
Unread 02-02-2010, 22:23
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Once again, this issue is NOT ABOUT the sizing box.
This issue could affect a 12"x12" robot. If the frame has an upper level in the bumper zone that is 12"x12" and a lower level that is 12"x12" below the bumper zone any fasteners sticking out of the lower frame are illegal per <R16>.
The very, very bad thing is that if fasteners stick out both inside and outside the bumper zone you were legal before Team Update 6 and now you're not. Making such a ruling at the end of week 3 is frankly unacceptable.
  #78   Spotlight this post!
Unread 02-02-2010, 22:53
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Paul Copioli View Post
No, no, no. This is not good job GDC! Bad GDC, bad GDC. We are in week 4 of the build season for Pete's sake. This makes no sense to me at all. On the scale of things that matter to them, this should be in negative land.
Good job GDC. I didn't need the sleep anyway.
Paul,
What part of rule <R16> did the GDC screw up?
<R16> During normal operation no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as permitted by Rule <G30>.
They gave us some freedom to have screw heads under the bumper but we had no right to expect that this would extend outside this space. There was a question, it was answered relatively fast and while there is time to work around it if you have to.
I don't see how we can blame the GDC.
Joe J.
Team #88, TJ2
  #79   Spotlight this post!
Unread 02-02-2010, 23:11
I guess I didn't fully understand the issue. So, to make this theoretical 12x12 team described above compliant, they would need to make their upper level say, 13x13?
  #80   Spotlight this post!
Unread 02-02-2010, 23:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Exactly. Or somehow modify things so the bottom fasteners don't stick out.
  #81   Spotlight this post!
Unread 02-02-2010, 23:43
President, VEX Robotics, Inc.
Joe,
Prior to update 6, the fasteners, etc within the bumper zone defined my frame perimeter. After update 6 & 7 they did not. What this means is that all of us who made sure the bolt heads within the bumper zone stuck out more than the bolt heads below the bumper zone to be within the rules are now illegal and it is the start of week 4.
In short, our robot was legal on Thursday, and now it is not. How can you not see a problem with that?
Even more ridiculous, if I have a sheet metal drive base and I have rivets all over it to hold it together, this update makes the rivets below the bumper zone illegal.
Ridiculous
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #82   Spotlight this post!
Unread 03-02-2010, 00:15
Chris is me's Avatar
AKA: Pinecone
I guess if you have your bumper mounting parts of the sheet metal chassis a quarter inch out from the rest of it, you could still rivet it.
I share your frustrations, though, despite no changes being needed for my team's robot. This isn't an acceptable week 4 change.
  #83   Spotlight this post!
Unread 03-02-2010, 00:19
Paul, I see exactly where you are coming from now that I understand the issue. This is a design-altering rules change, not just a clarification. Perhaps they should make it so bolt heads may be excluded, at the discretion of the team.
  #84   Spotlight this post!
Unread 03-02-2010, 00:27
AKA: Dr. Joe
FRC #0088 (TJ2)
Joe,
Ridiculous
You are right about the idea that if you line up rivet or bolt heads or whatever. I missed/forgot that (I say forgot because I knew it at one point but not at another). I apologize to you, Paul, for not understanding your point of view.
As to the rivets below the bumper zone, unless they were lined up with ones in the bumper zone then they would have always been illegal. Am I right on this?
I see at least 3 possible paths.
  1. First, FIRST could realize that they were trying to do one thing and (perhaps) did another instead (by taking away the heads on the bumper zone they took away the head below it) and go to a mixed definition that allows for your heads to be legal as long as they are below heads in the bumper zone but for bumper mounts to be secure.
  2. Second, FIRST could allow all fasten heads to count for robot overall size but not for extending beyond the FRAME PERIMETER
  3. Third, Teams could mount a small (hopefully light) spacer on the robot at the bumper zone that spaces the FRAME PERIMETER over the tops of the fastners.
I think 2 is the most reasonable given where we are. I don't think they are going to go for it. I suppose 3 is the safest bet because it is in the team's control.
Joe J.
Team #88, TJ2
  #85   Spotlight this post!
Unread 03-02-2010, 00:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Joe J.
This seems like a pretty good summary of the options at this point.
Our team is hoping for #2 and planning for #3.
  #86   Spotlight this post!
Unread 03-02-2010, 00:53
AKA: Pinecone
I guess it's not a quick fix, but perhaps teams whose robots break this new rule change could slap some material over their bumper zone to make it thicker? i.e. 4 thin pieces of lexan as long and wide as the bumper or something, with holes for the bolt heads, that makes the bumper perimeter thicker. It's easier than redesigning a drivetrain because rivets or bolts stick out.
  #87   Spotlight this post!
Unread 03-02-2010, 01:22
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Wow update 7 is frustrating... so this means our screw heads and washers keeping our drive shafts in are now illegal, great.
Yea I know is some sort of wording this was always illegal, but I don't undersand why FIRST would go to the effort, in week 4, to define how we must design the area beneath our bumpers in such a specific way. In all honesty this is a very unenforceable rule defined so late in the season, that some 'elite' teams are going to have a tough time meeting. I feel sorry for teams who built their frame out of sheet metal and rivits. These rulings makes me think that the GDC didn't even consider the realistic consequences of this definition, and how unenforceable it will be.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #88   Spotlight this post!
Unread 03-02-2010, 01:32
AKA: Dr. Brooks
no team (WRRF)
Recognizing this gray area in the rules, we always knew that we could glue on a spacer in the bumper zone to exceed the extension of any fasteners (in our case welds) lower down on the robot. At this point it looks like this is what we will have to do and we will need to make it weigh as little as possible.
Any suggestions for a suitably light spacer material?
Eugene
  #89   Spotlight this post!
Unread 03-02-2010, 01:44
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Eugene
Eugene,
ABS or Delrin works great as a light spacer material. If you want something easier to find use pvc.
-RC
R.C.
MadTown Robotics Team 1323
  #90   Spotlight this post!
Unread 03-02-2010, 01:51
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Well this make sheet metal designs a bit more difficult... back to the old flat head bolts with PEM nut option.
For those which cannot change their fasteners to flat head bolts, here's the McMaster part number that I think will save a lot of teams this year: 8782K12
1" wide x 1/4" thick polypropylene strips at $0.53/foot. Polypropylene is among the lightest and cheapest commonly available plastics, but even still, installing this strip around the outside of your robot perimeter will add just over a pound.
For comparison, using a 1/4" x 1" strip of Lexan will add over 1.3 pounds.
Art Dutra IV
世上无难事,只怕有心人.
kicker extending outside of robot caincteam2777 Technical Discussion 5 17-01-2010 22:42
Frame Perimeter x Bumpers sloteera Rules/Strategy 8 14-01-2010 11:18
Frame Perimeter? jimbot General Forum 2 10-01-2010 13:48
Holding of Game-Pieces Outside the Robot Perimeter MikePres General Forum 2 24-01-2009 07:21
Ramps extending outside of the home zone Shomron1690 Rules/Strategy 31 20-03-2007 13:49
