Go to Post If this doesn't show up in spotlight at some point I'm almost going to be sad. - Andrew Schreiber [more]
Unread 02-02-2010, 20:36
ygd ygd is offline
FRC #3341 (Manhattan Project)
ygd is an unknown quantity at this point
Exclamation Leaking Solenoid?
We pretty much have our pneumatics system working perfectly, except for one thing: our solenoid is leaking.
It's a recent (2010) Festo solenoid and it's not letting the circuit go above 40 psi. Is our solenoid busted and needing replacement or is this just a programming/electrical error?
Unread 02-02-2010, 20:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Leaking Solenoid?
Did you tighten the hose fittings on the valve? there is a hex hole in them that you can use a hex wrench on.
Unread 02-02-2010, 21:24
ygd ygd is offline
We can't seem to find the hex hole to tighten the hose fittings. Is the valve not the solenoid?
Unread 02-02-2010, 23:56
MrForbes's Avatar
AKA: Jim
I assume you are talking about this Festo solenoid valve?
It came in a bag with some wires and 3 round metal fittings that screw into the holes (where the arrows are in the picture). Two go on the top, one goes on the bottom in the middle. The round metal fittings have no way to grip them on the outside, but they have a hex shaped hole in side that you can fit a hex wrench into.
If you are talking about something else, please describe it or take a picture, so we can try to help you
Unread 03-02-2010, 00:17
ygd ygd is offline
We have most of those in. We don't have the bottom ones on the sides in. Although we don't have any hose going there.
Unread 03-02-2010, 00:31
MrForbes's Avatar
AKA: Jim
The two bottom ones on the ends are for the exhaust, you do not connect hoses there. The air from the regulator goes into the middle bottom port. The two top ports connect to the two ends of the pneumatic cylinder.
Make sure you push the hose all the way into the fittings, so it seals well.
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Microwave leaking? sanddrag Electrical 8 30-08-2006 20:06
solenoid/spike greencactus3 OCCRA Q&A 1 11-09-2004 09:54
Leaking piston? Bill Becker Pneumatics 6 23-03-2004 18:10
