Go to Post The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 17-01-2010, 13:40
gwpierson gwpierson is offline
FRC #1764
gwpierson is an unknown quantity at this point
New Accelerometer and LabView
So the new accelerometer for 2010 gives you the choice of hooking up to either spi or i2c. The documentation says that these should be attached to the digital sidecar in either the i2c area or DIO 1-4. However, the vi's associated with the accelerometer only allow analog inputs. I know last year's accelerometer required analog inputs, so i'm assuming the vi's are a carry over. So: A) Does someone have some accelerometer vis that will allow digital inputs? or B) Can this accelerometer be plugged into the analog breakout?
Unread 17-01-2010, 13:54
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: New Accelerometer and LabView
Unfortunately, it's not analog this year; it goes into the I2C port on the digital sidecar.
Perhaps this thread will help:
http://www.chiefdelphi.com/forums/sh...d.php?p=900068
-- Marshal Horn
Unread 17-01-2010, 14:21
FRC #1764
Hmm, thanks for the reply. I had a feeling that was the response i was going to get about B). However, here's hoping someone has a workaround for the analog .vi's. If not, the team will probably just have to use the analog acc from last year.
Unread 17-01-2010, 14:28
There is an example in LabVIEW for the I2C accelerometer.
Unread 17-01-2010, 15:19
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Really?
I see no mention of "accelerometer" or "I2C" in Begin.vi.
-- Marshal Horn
Unread 17-01-2010, 15:26
Originally Posted by kamocat View Post
Really?
In the LabVIEW examples, not the framework code.
Unread 17-01-2010, 17:34
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Thank you!
I'll move the functions to my palette.
Do you know if the I2C port supports multiple-byte reads?
If so, does this mean it could do continuous measurement, without having to re-address to the accelerometer?
-- Marshal Horn
Unread 17-01-2010, 21:33
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
It does... but only up to 7 bytes per transaction (i.e. without readdressing).
Unread 03-02-2010, 00:44
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Well, as a follow-up:
I finally got around to wiring the accelerometer up. For some reason, I'm not getting any accelerations back from it.
I haven't bothered yet to see if I'm actually connecting to it in the first place. However, I did test the wiring before turing the robot on.
Did you know: Only one of the two sets of PWM-style I2C headers are connected? (The lego-style female RJ-14 is connected as well)
-- Marshal Horn
Unread 03-02-2010, 01:10
That's cause the 4 pins farthest from the RJ connector are slow digital outputs, not I2C. You'll notice that the silk screen on the Sidecar says "OUT" next to them. We never bothered to add support for them to WPILib, but the FPGA layer supports them.
Unread 05-02-2010, 00:41
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Originally Posted by Error code -44095
The I2C sensor identification string did not match. The expected sensor is not at the address and bus specified. The sensor was expected to return "Address: 58" but instead returned "Sensor did not respond."
I2C.lvlib:Read.vi>>I2C.lvlib:Open.vi>>ADXL345 I2C Open.vi>>i2c accel.vi
<time>06:23:27 02/05/2010
<unique#>1
Any ideas why this might be? I double-checked the wiring. I even checked the code to make sure it had the right address.
-- Marshal Horn
Unread 05-02-2010, 00:48
Triple check the wiring? It's usually cause by a wiring issue. Do you happen to have a logic analyzer that you can use to look at the bus?
Unread 05-02-2010, 00:53
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
No, I just have an O-scope. (I don't think it'd show me much in this case, or I would use it)
The battery was low, so I put the bench-test on an external 13v supply. No change in response.
Should I try running a Driver Station, to see if that makes a difference?
I guess this brings up the other question:
How easy is this board to fry from heat or static electricity?
-- Marshal Horn
Unread 05-02-2010, 15:15
Well... if you can watch the data and clock lines you can check that the address is being sent correctly and that the address is actually not acked.
The driver station should not need to be connected as long as your code is getting called. Never hurts to have it, though. One less variable to worry about.
No idea... I've never seen one die.
KoP Gyro and Accelerometer Placement DavidB Electrical 6 05-02-2010 09:18
New TipJar Training Video - Autonomous Mode and LabVIEW Training Giveaway LVMastery NI LabVIEW 3 28-01-2009 07:06
New LabVIEW TipJar Tutorial Video: Scalability, Modularity and Style. LVMastery NI LabVIEW 0 18-01-2009 14:56
LabVIEW Training and new control system demonstration 10/17-10/19 in Frazier Park, CA Joe Ross NI LabVIEW 0 25-09-2008 13:25
gyro and accelerometer problems paulcd2000 Programming 6 16-02-2008 15:17
