Go to Post 254 bends CIM shafts every now and then in the drivetrain. I didn't believe it was possible until I saw it myself. - AustinSchuh [more]
Unread 01-10-2010, 12:12 AM
chronon's Avatar
chronon chronon is offline
AKA: Tim
FRC #0668 (Apes of Wrath)
chronon is an unknown quantity at this point
Cypress FirstTouch hex file?
In the benchtop instructions we are told to go to where we downloaded the "FRC_IO.v1.hex" and select the "FRC_IO.v2.hex file", yet my team and I can't seem to figure out where those files are obtained from.
Thanks in advance for any help we receive!
Unread 01-10-2010, 09:40 AM
Re: Cypress FirstTouch hex file?
The hex file should be installed along with the other files for the driver station. It should be placed into the directory All Users/Documents, or All Users/Public documents, depending on what the OS calls it.
Greg McKaskle
Unread 01-10-2010, 06:43 PM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
[quote=chronon;895411]In the benchtop instructions we are told to go to where we downloaded the "FRC_IO.v1.hex" and select the "FRC_IO.v2.hex file", yet my team and I can't seem to figure out where those files are obtained from.QUOTE]
You only need the v2 file... the documentation has a typo where it references v1. As Greg said, it should be installed by the Driver Station Installer at: www.usfirst.org/frccontrolsystem then click on Mandatory Driver Station Update. This instaler can update the classmate or be installed on any other computer to run the driver station software.
Unread 01-27-2010, 09:45 AM
RobbieAG RobbieAG is offline
AKA: Robert Agresti
FRC #2655 (Flying Platypi)
RobbieAG is an unknown quantity at this point
This file (FRC_IO.v2.hex) can be found in C:\Documents and Settings\All Users\Documents after installing the driver station update.
Unread 02-03-2010, 01:32 AM
anyheck anyheck is offline
FRC #2242 (Cougars)
anyheck is on a distinguished road
Should the "Warning!--> Debug mode enabled....." cause any concern?
It shows up in the screenshot in the documentation, but no mention of it is made.
Any idea how to 'turn it off in PSoC Creator?'
Thanks,
Sten
Unread 02-03-2010, 03:02 AM
Thanks,
Sten
Nothing to worry about. I guess when I released it I built the debug version of it accidentally. Should not hurt anything.
Unread 02-08-2010, 12:29 PM
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
It was in C:\Documents and Settings\All Users\Shared Documents in my case
Phil Malone
http://www.GEARSinc.org
creating hex file seanl Programming 4 02-03-2007 10:08 PM
"Error.MCP" file after HEX file trans iwdu15 Programming 1 01-24-2007 08:05 PM
Hex file downloads Ryan M. Control System 2 10-29-2005 07:50 PM
hex file garbage? sciguy125 Programming 2 07-04-2005 11:04 PM
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 02-28-2004 12:12 PM
