Re: Invariant FPGA Image Version Error?
Wow. This one really stumps me. It reports a version error even though it is clearly able to deploy the image and even print the matching version (the "hardware" GUID, version, and revision). I looked closely at the code that generates this messaage, and it is caused by not being able to open the handle to the FPGA image after it is downloaded. I'll have to get back to you on this one.
-Joe |
Hi,
I'd like you to replace the attached file (unzipped, of course) on your cRIO and reboot your controller, capturing the boot messages just like you did before. It goes in "/ni-rt/system/". I added a few prints that will hopefully point to what is going on. Thanks, -Joe |
| Error "IFI>Master Code Version: 8 " | mecanumbot | Programming | 0 | 24-01-2010 01:30 |
| cRIO Image version? | Chris11246 | Programming | 1 | 14-02-2009 16:44 |
| v11 cRIO Image Error | Team1710 | Programming | 7 | 14-02-2009 12:56 |
| FPGA Image | idahorobot | FRC Control System | 1 | 12-02-2009 01:23 |
| Error in Compiling the Camera Code (B&W Version) | VetteSlick | Programming | 7 | 20-01-2006 20:50 |
