Go to Post A stack is a stack is a stack. (How Profound!) - Paul Copioli [more]
Unread 02-02-2010, 15:50
Re: Tank Treads
I doubt it. I've seen that kind of track since this rule became one of the "standard" rules.
"Other attachments" may refer back to the days before this rule was implemented, when teams used metal cleats, file cards, Velcro, and pretty much anything else they could figure out how to use as a traction device as a traction device. The carpet was constantly getting destroyed--it's a brand-new carpet each regional these days, and often doesn't show too much damage, but if you get a really badly torn up one at the end of the event, that was Thursday or Friday damage back in those days. If you had a really light day, that is.
Unread 03-02-2010, 06:41
devodl devodl is offline
AKA: Steve Deal
FRC #0578 (R3 - Red Raider Robotics)
devodl is just really nicedevodl is just really nicedevodl is just really nicedevodl is just really nicedevodl is just really nice
Re: Tank Treads
Eric,
After re-reading this rule and some of the history that brought it about I think you are right. IMHO the "other attachments" phrase was added so that someone wouldn't go out and purchase a track and then pop rivet nasty carpet rippers to the track.
We kept carpet happiness in mind as we fabricated our track.
Steve
Unread 03-02-2010, 07:34
Re: Tank Treads
So you know (and to keep this in mind) some regional events take place in gyms on hardwood floors and others take place on soft rubber composite floors. This rule is to prevent damage to the subsurface as well as the carpet. As to rubber tracks attached to chains, the answer becomes a yes and no. Yes if rubber is the only material that contacts the carpet and is not so aggressive the it digs into the carpet fibers. No if the attachment uses fasteners that also contact the carpet and have the potential for damage. For any contrivance used to move the robot, your design should not be one that leaves (or has a potential to leave) a residue or lubricant on the carpet.
Unread 03-02-2010, 17:04
AKA: Steve Deal
Re: Tank Treads
Thanks for the advice/confirmation about the intent of <R08>.
Thanks also for the heads up on avoiding damage to the subsurface.
I think we have it covered but we plan to send some pics to the GDM on TIMS to get their opinion.
Tank Treads Andrew.Jensen General Forum 37 14-01-2010 10:53
Tank Treads??? SLA Kit & Additional Hardware 2 16-01-2007 20:53
Tank treads teh_masterer Technical Discussion 3 11-01-2006 18:11
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
