Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Unread 01-02-2010, 15:47
kick3nitx360 kick3nitx360 is offline
AKA: Dave.
FRC #1626 (Falcon Robotics)
kick3nitx360 is an unknown quantity at this point
Send a message via AIM to kick3nitx360
CONTROL SYSTEM GLITCH
whenever the robot is on, the speed controllers and actuators click and stop working for a split second multiple times. Any ideas as to why this is happening.
Unread 01-02-2010, 15:51
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: CONTROL SYSTEM GLITCH
Please don't take this the wrong way; I speak from personally having done this several times: change your battery out for a fresh one. With a dead battery, the control system will boot up and work when idle, but as soon as you touch the joystick or the compressor turns on, the voltage will dip, causing the control system to turn off for a moment, then come back up.
It could be something else; if a freshly-charged battery doesn't cut it, let us know and we'll help.
Aren't signatures a bit outdated?
Unread 01-02-2010, 17:37
The clicking may be circuit breakers tripping. With the power off and the battery removed, check every wire for correct polarity. What you describe could be a low battery or a dead short on the battery. Don't touch anything with your fingers. If it is a circuit breaker something is bound to be hot!
Unread 02-02-2010, 00:45
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
In addition, what orientation is your bot, and what surface are you running it on? We can't run our bots in our room very well because the carpet has padding that gives them too much traction to skid-steer: they end up tripping the self-resetting circuit breakers when the cims stall.
Unread 02-02-2010, 10:17
Another possible problem is System Watchdog Errors. You can look at the diagnostics tab to see if watchdog errors correspond to your glitches.
Unread 02-02-2010, 20:05
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
Be careful, because the playing surface is also carpet!
Unread 03-02-2010, 11:15
peter1626 peter1626 is offline
peter1626 is an unknown quantity at this point
Im a programer from kick3nitx360's team and was wonder if this was the battery what voltage would show on the dashboard? also were only running for 30 min and sometimes only 1 min before the clicking starts, could the battery drain that fast?
Unread 03-02-2010, 11:29
Generally the answer is no but if you have a loose wire, the answer is yes if the battery has a significant load. Battery voltage should show 8-12 volts while driving.
new control system Sam2197 FRC Control System 2 22-11-2008 13:17
Control System wmatt2014 Control System 9 01-02-2008 09:56
Major Glitch? Kyle Fenton General Forum 10 12-11-2004 16:09
Control System archiver 2000 0 23-06-2002 22:51
control system archiver 2000 1 23-06-2002 22:04
