Go to Post Pulling off an off season during a hurricane isn't easy. - Arefin Bari [more]
Unread 02-03-2010, 01:47 PM
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
"VxWorks6x_10.32.42.2 (Registry localhost)"
Here is the error report from trying to connect to the cRIO:
Error connecting to 'VxWorks6x_10.32.42.2' (Registry localhost). Failed to launch target serverPossibly caused by: Back-end not connected.
Removed dead entry from Registry!
com.windriver.ide.target.exceptions.TargetServiceE xception: Error connecting to 'VxWorks6x_10.32.42.2' (Registry localhost). Failed to launch target server
Caused by: com.windriver.ide.target.exceptions.TargetServerDi edException: Back-end not connected
at com.windriver.ide.target.wizard.connectstrategies. tgtsvr.TargetServerLauncher.threadLaunchTargetServ er(TargetServerLauncher.java:497)
at com.windriver.ide.target.wizard.connectstrategies. tgtsvr.TargetServerLauncher.launch(TargetServerLau ncher.java:562)
at com.windriver.ide.target.processes.ProcessLauncher .run(ProcessLauncher.java:133)
at java.lang.Thread.run(Thread.java:595)
I'm new to WindRiver and cRIO, so I don't know what to do at this point.
This occurs on a physical machine without admin privilages and on a virtual machine with admin privilages.
Has not been tested on the netbook supplied by FIRST.
Unread 02-03-2010, 02:34 PM
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: "VxWorks6x_10.32.42.2 (Registry localhost)"
Not much to go on here in terms of relevant detail.
Is the cRio powered up, running, and properly connected (via router or not) to the PC? Can you ping the cRio from the PC on which you're running Workbench?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 02-03-2010, 03:03 PM
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Have you followed the "Getting Started with C++" Manual here:
http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
I received similar errors until realized i had not selected the Kernel image as discussed on page 6.
Good Luck!
2010-? - AIR Strike (Team #78)
2007-2009- Rhode Warriors (Team #121)
2003 - Team #190
1997-2002 - Bobcat Robotics (Team #177)
http://www.tomschindler.net
http://www.drivexc.com
Unread 02-03-2010, 05:28 PM
FRC #3242
I have read and followed it to the letter.
I still get the same results.
I'll try again though...
Edit: I tried pinging the device via the usb chord and it timed out. What could this mean?
Unread 02-03-2010, 05:52 PM
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
I'm just giving my two cents here, but could it be possible that the network setup on your virtual machine leaves something to be desired? If it pings without response, there is only one thing that does that: it is not connected. Lack of admin rights on a physical computer can do this too, since you need to change network settings.
Unread 02-03-2010, 05:57 PM
FRC #3242
I just tried it on the FIRST netbook, and I get similar results even though I have admin rights and the firewall is turned off.
Is there anything else I have to do to set it up that's independent of windriver? If so, I haven't done it.
Edit: I think I have the wrong thing. The cRIO is the little microcontroller right? Or is it the thing that goes on the actual robot?
Unread 02-03-2010, 06:25 PM
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
The cRIO is the long, heavy rectangular box that the 'cards' slot into. Has a lower section that has some dip switches, a serial port and two ethernet ports.
I would suggest going back to the beginning and making sure you didn't miss anything. Work through this, and then this.
Start a new workspace to do this, rather than try persevere with what you have. When you have got everything working successfully, and if time permits, then go back to your current workspace and try to figure out what was different.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 02-04-2010, 03:10 PM
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
the usb device that connects to the DS that you are refering to sounds like the cypress IO board. if you can see electronics on a blueish circuit board that has stuff on it (and connects to a 9 volt batten) it is the IO board. this is non-essential (unless you are using it)
Watchdog.Kill();
Unread 02-11-2010, 05:08 PM
FRC #3242
Thank you, we have it figured out now. It was just confusion on how the system worked that was our problem.
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 04-19-2007 08:06 AM
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 08-10-2005 10:55 AM
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 09-07-2004 07:53 PM
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 02-22-2004 02:55 AM
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 06-24-2002 12:54 AM
