Go to Post Okay, okay, I'll bring your Krispy Kremes to the Championships ... I bought them right after the '03 Championships ... I'm sure they are still in the attic - Natchez [more]
Unread 02-02-2010, 18:54
FlyingHedgeHog's Avatar
FlyingHedgeHog FlyingHedgeHog is offline
AKA: Jonathan
FlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud of
2898 electrical board
It might not be super-compact the whole board looks really nice. Everything is on mass-quick-disconnects, and we can take the whole thing apart in 10 minutes or so. This probably would've been nice last year when a Victor caught fire but hey, what are you gonna do? Oh, we swapped out the traditional Victor fans for higher performance ones with LEDS. (As you can probably see)
Name:	2010 electrical board.jpg
ID:	8475  Click image for larger version
Name:	2010 electrical board2.jpg
ID:	8476  Click image for larger version
Name:	2010 electrical board3.jpg
Unread 02-02-2010, 19:03
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: 2898 electrical board
You cannot use the LED fans, they are not provided in the KOP or with the Victors.
They use motors, and the only motors allowed are those in the KOP and those included with the Jaguars and Victors as fans (and those are only allowed to cool the Jaguars and Victors, nothing else). Also, from what i've seen, the ability to rapidly pull out a physical electronics board gives no advantage, since the physical board adds weight over just attaching electrical components to the frame, or at least weighs more then perforated aluminum, and the quick disconnects won't help if a Victor dies.
It still looks good, just no LED fans.
If a Victor caught fire, then you probably got metal shavings in it. They almost never ever die, except for metal shavings.
Kettering Motorsports
Unread 02-02-2010, 19:09
mikelowry mikelowry is offline
FRC #1771 (N.G.R.)
mikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to all
I like the way you mounted the cRIO above the PD board
2008 Xerox Creativity Award - Championships
2009 Rockwell Automation Innovation in Control award - Peachtree
2009 GM Industrial Design Award - Palmetto
2009 Palmetto Champions <1771 2415 21>
Unread 02-02-2010, 19:16
AKA: Jonathan
Oh, I know the cause of it catching fire. Everyone just freaked out and wanted to get it off asap. The quick disconnects are because we want to be able to cannibalize parts from the boards. We don't want to have to buy new electronics every year, and doing any other kind of connection takes too long if we want to get a previous year's robot working again.
As far as the fans go, the inspectors didn't have an issue with it last year when we did the same thing. Thanks for the input, I'll make sure we have back-ups with us just in case the inspectors don't like them.
Unread 02-02-2010, 19:27
apalrd's Avatar
More Torque!
VRC #3333
Originally Posted by FlyingHedgeHog View Post
The quick disconnects are because we want to be able to cannibalize parts from the boards...
I was talking about the big quick disconnects on the bottom of the board, not the ones on the individual Victors. Fork terminals don't take that much time to screw/unscrew.
Unread 02-02-2010, 22:05
How easy is it for you to remove or replace a circuit breaker? I'd be concerned about how inaccessible they are under there.
Unread 02-02-2010, 22:12
AKA: Jonathan
The breaker is on the left-hand side of the board if the battery is on the far side, and you're looking at the board head on. It's not hard to get to. And that whole top layer comes off in like 10 seconds if we need at the PD.
Unread 02-02-2010, 22:26
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I obviously don't know what superstructure this is going to be in, but you'll need to be careful about Robot signal light visibility from outside the robot <R59>.
I've always been in favor of easy electronics removability so that you can transfer it easily back and forth between a prototype and the production chassis. It would certainly be handy if you're planning to retain your electronics package as part of your withholding allowance.
Unread 02-02-2010, 22:39
AKA: Jonathan
Oh, we're mounting the light somewhere else. But even if it was mounted there it would probably be okay because it has a roll cage with poly carbonate shield to prevent balls from going in. Nothing besides the roll cage is mounted higher on the robot.
Unread 03-02-2010, 08:42
There is no rule that prevents cooling fans from being used on the robot and as pointed out, have been allowed for many years. However, only the supplied fans for the Victors can be wired to the power input of the Victors.
<R60>
E. The supplied fans attached to the Victor speed controllers may be powered from the Victor power input terminals.
Any other fans have to be wired to a circuit breaker on the PD. Please remember that only one wire can be inserted in each Wago so that means you have to come up with some other distro for multiple fans. Also, if you use a quick connect 1/4" terminal on the Victor input you can eliminate the Power Poles which introduces another potential failure in the electrical system. The push on terminals give you the same abilities but with two less terminations (and the added resistance) per Victor.
Unread 03-02-2010, 11:09
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Is the fact that the PD is under the cRio a violation of R44-H?
<R44>-H
The Power Distribution Board and all circuit breakers must be easily visible for inspection at each FRC event
Unread 03-02-2010, 14:15
AKA: Jonathan
The top piece comes off so you can get at in like 10 seconds or so.
Unread 03-02-2010, 14:25
It could be but it is hard to tell from the pictures. It appears that an inspector should be able to see the breakers. Off note, wiring in the high current side of the PD can only be fed with 40 amp breakers so it is easy to tell that #12 or larger wire is connected to the PD at those terminals. The 20 and 30 amp breakers would be a little harder and may require you to raise the hood to see inside. Be prepared.
Unread 03-02-2010, 14:59
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Team 2080 did something similar to your electrical system last year. You may want to watch out for being able to us your wago tool on the PD board, and with the breakers. I know you've said that it only takes 10 seconds to take off the top plate, but you may also want to worry about being able to get to the section of the robot where the electronics are and still taking it off, and then also what you will do with the top plate after you take it off, it may seem like nothing but if during competition you need to get to the PD board for some reason you won't want that top plate getting in your way.
I do hope this design works for you though (means your validating my design), and good luck in competition
Blown up electrical board DhavalVashi Electrical 18 19-02-2009 17:12
pic: Electrical Board team63 Extra Discussion 3 05-02-2009 15:33
Electrical board materials? gwilliam Electrical 15 28-01-2009 10:53
Metal Electrical Board aaeamdar Rules/Strategy 3 16-02-2008 20:49
pic: 494 Electrical Board. want2modmygt Robot Showcase 2 12-02-2006 14:28
