Go to Post When I mentor other people in programming... they either get pointers or they don't. - JamesTerm [more]
Unread 02-03-2010, 02:41 PM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Can't see any values on dashboard
Originally Posted by Kyledoo View Post
Thank You!! Everyone kept saying MODIFY THE DASHBOARD!! but I am having enough trouble figuring out the encoders right now, and we have more sensors we want to set up. Where is the diagram though, I see the project explorer and it lets me open of the GUI. Other than figuring that out, I have never used labview. Since you have been so helpful, would you mind me asking you about an Encoder Example, maybe even one that sends it to the dashboard? If you could point me to something that would be very helpful. WPI documentation seems to be very lacking in the encoder area.
Here's some code for unit testing the Encoder class:
	double position4x, position2x, position1x;
	DigitalInput qA(5); // Digital I/O 5 on slot 4
	DigitalInput qB(6); // Digital I/O 6 on slot 4
	Encoder encoder4X(qA, qB, true);
	Encoder encoder2X(qA, qB, true, Encoder::k2X);
	Encoder encoder1X(qA, qB, true, Encoder::k1X);
	// 6 inch wheel (pi*d) is 18.85 inch circumference; 24:40 tooth sprockets; 250 pulses per rev.
	encoder4X.SetDistancePerPulse(18.85 * 0.6 / 250.0);
	encoder2X.SetDistancePerPulse(18.85 * 0.6 / 250.0);
	encoder1X.SetDistancePerPulse(18.85 * 0.6 / 250.0);
	Jaguar rightMotor(2);
	rightMotor.Set(-1.0);
	Wait(2.0); // wait for motor to get up to speed
	encoder4X.Reset();
	encoder2X.Reset();
	encoder1X.Reset();
	encoder4X.Start(); // start counting
	encoder2X.Start();
	encoder1X.Start();
	Wait(5.0); // wait for some distance to be covered
	position4x = encoder4X.GetDistance(); // get position in inches
	position2x = encoder2X.GetDistance();
	position1x = encoder1X.GetDistance();
This code is only interested in position, not speed. Hope this helps.
-Joe
Last edited by jhersh : 02-03-2010 at 02:46 PM. Reason: Make it a bit more interesting...
LabVIEW Video Tutorial: Customizing The FRC Dashboard To See Your Data LVMastery NI LabVIEW 0 02-10-2009 01:50 PM
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 10:34 PM
Bug? Can't seem to delete any of my PMs DanL CD Forum Support 2 12-15-2003 11:12 PM
You can't see through an untouched starting wall of boxes Digo General Forum 31 01-11-2003 12:01 PM
