Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 03-02-2010, 10:01
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
How to get the camera to show images on the dashboard?
Hi iam from team 1514 and we are experiencing some difficulties.... First of all we CAN NOT see the dashboard when we start the classmate pc. We only see the bottom half of it...We manually went to the Developer mode and looked for : dashboard.exe, and ran it. Still no IMAGE!!! We have configured the camera perfectly and yes it does receive the image because we went to , 192.168.0.90, and we could get the live feed. But not in the dashboard.exe .. Plz HELP!!!
-Chinmay
Unread 03-02-2010, 10:34
Intel i7 Intel i7 is offline
FRC #3540 (Wildcat Robotics)
Team Role: Driver
Intel i7 is an unknown quantity at this point
Re: How to get the camera to show images on the dashboard?
yes, please help. im from team 3196 and we are having this same problem
Unread 03-02-2010, 10:44
The "bottom half" is the Driver Station application. The "top half" is the actual Dashboard.
The Driver Station doesn't start the Dashboard application when a remote dashboard has been specified. Make sure you've selected the local dashboard on the configuration tab.
If you aren't seeing camera images, it's possible you still haven't successfully updated the Driver Station software completely. The "new" and correct Dashboard has a compass indicator at the bottom of the right side of the window. There's an issue with the DS update that doesn't replace the original version of the Dashboard until you run it twice, first to uninstall the files and then to reinstall them.
Unread 03-02-2010, 13:47
You can look at the creation date of Dashboard.exe too, to tell if it's old.
The current Dashboard will have a 2010 date (1/8/2010), while the older one will be from 2009 (9/22/2009).
Unread 03-02-2010, 14:54
hamosad1657 hamosad1657 is offline
FRC #1657
hamosad1657 is an unknown quantity at this point
There is a link for the Driver Station Update (include Dashboard):
http://ftp.ni.com/support/labview/FI...1.0for2010.zip
It will solve the problem.
Unread 03-02-2010, 17:49
FRC #1514 (Vikings)
Tnx i got the camera view BUT i have connected wirelessly, all the communication, robot code, and stop botton are green, i can also drive the robot but i can NOT see the image. Yes i have connected the camera to the C-Rio through a crossover and it is working because i went to the ip : 192.168.0.90 and it gives me the live feed. please help US!!!!!!!!!! Much appreaciated
-Chinmay
Unread 03-02-2010, 18:21
FRC #1514 (Vikings)
Here is the error which i get when i plug the camera in directl to the classmate.
The error:
ERROR <code> -44003 occured at Camera.lvib:issue HTTP Request with Authentication.vi>>Camera.lvlib:issue Get.vi>>Camera.lvlib: Set Image Appearence Property.vi>>Camera.lvlib:Set Enm Appearance Property.vi>>Camera.lvlib:Set Image Size.vi>>Vision Processing.vi>>Rbot Main.vi
<time>17:31:26 02/03/2010
FRC: Operation failed due to a communication failure with the camera.
ERROR<code>-44003 occured at Camera.lvlib:issue HTTP Request with Athentication.vi>>Camera.lvlib:Read JPG.vi>>Camera.lvlib:Acquire Image.vi:1
<time>17:31:23 02/03/2010
ERROR<code>-44003 occured at Camera.lvlib:issue HTTP Request with Authentication.vi>>Camera.lvlib:Read JPG.vi>>Camera.lvlib: Acquire Image.vi:1
<time>17:31:19 02/03/2010
No Change to Network Configuration: "Local Area Connection"
I/O unit not detected or not installed correctly.
-Chinmay
Unread 03-02-2010, 20:13
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
We are having the same problem. I had previously installed the 2010 DS update (linked above), but for some reason our dashboard application was not actually updated (no gyro angle was on it).
I used the installer to remove the applications from the computer, then re-installed. Now we have the correct versions of the DS and the dashboard, but are still getting the error messages listed above.
I;ll update if we figure it out.
Unread 03-02-2010, 20:26
otherguy's Avatar
sparkE
AKA: James
I just restarted everything and looks like it's working.
I'm still getting some of the error messages still but video is streaming and the target detection is working.
Looks like the uninstall/re-install fixed it. Thanks for the help.
Unread 03-02-2010, 20:32
If you've got your Dashboard all updated, then the next step is to make sure the camera is setup properly.
Hook the camera directly to the Classmate and use the "Setup Axis Camera" icon you'll find on the desktop.
P.S. Good news!
Unread 03-02-2010, 22:53
FRC #1514 (Vikings)
yes i have connected the camera directly to the classmate pc and configured correctly. I have done the Setup axis camera but still nothing!!! Cannot see anything in the dashboard still>! I can tell its configured correctly because i have went to 192.168.0.90 and got the live feed perfectly fine. But not on the dashboard ... please help Tnx
-Chinmay
Unread 03-02-2010, 23:02
Does your Dashboard look like the picture on the left, or the one on the right?
ID:	8488  Click image for larger version
Unread 04-02-2010, 07:43
FRC #1514 (Vikings)
Our dashboard looks like the one on the left. Is it suppose to look like the one on the right>?
-Chinmay
Unread 04-02-2010, 10:04
Yes, that's probably the most common problem teams are running into.
The left one is from last September and doesn't work with the current camera feedback.
The one you want is the one on the right.
Two ways to get the correct one:
  • Delete the existing Dashboard files in: C:\Program Files\FRC Dashboard
  • Reinstall DSUpdate1.0
or
Unread 04-02-2010, 17:20
FRC #1514 (Vikings)
Thx for the information it worked, now we can see the image on the dashboard BUT we can't get the camera to track the target.
-Chinmay
Lost the camera part of the dashboard... 1168Programmer FRC Control System 5 15-02-2010 10:30
yet another No Camera Images on Dashboard thread oddjob C/C++ 11 29-01-2010 20:53
Very Basic: Get a program running on the cRio that will show video on Classmat isaacdl Control System 6 23-01-2010 17:33
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
