Go to Post Wow, my dad's sadistic nature is rubbing off on me. - Lil' Lavery [more]
Unread 30-01-2010, 10:26
I am error's Avatar
I am error I am error is offline
The Error
FRC #0686 (Bovine Intervention)
I am error is an unknown quantity at this point
Arrow Holonomic Drive Example?
Does anyone know if first has a an example of the Holonomic Drive in labview. I know there is a blovk for it, but i dont understand how the crontrols work with it. If anyone knows or has an example that would be great thanks.
I am Error. Yes.
Unread 30-01-2010, 11:27
bakketti bakketti is offline
FRC #0443 (Freelance Robotics)
bakketti is an unknown quantity at this point
Re: Holonomic Drive Example?
Haven't found any FIRST resources but we have been referring to this paper: http://www.scipub.org/fulltext/ajas/ajas351831-1835.pdf
In addition we set up a simple PC simulator that allows us to take PC joystick, pass them through a modified Holonomic Drive algorithm and output respective PWMs on each wheel's channel. Theres a diagram in the paper above that shows how wheel speeds and directions cause different vehicle reactions. Very very handy.
Unread 30-01-2010, 19:24
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Here's a very oversimplified way to do it.
You need to open four motors in begin.vi (Open4Motors.vi) instead of the 2 motors.
You need to make the refnums agree as well.
The following would be what your teleop.vi would look like. The case structure would be the inner case that already exists and the open and get blocks would be outside the outer case.
I don't show anything connected to the rotate input, but you can add that pretty simply. Generally, you'd connect the Y-axis to the rotate input and keep both the other inputs set to 0 to use the rotate. Just add another case and feed it with a button.
This is not meant to be complete. It's more an idea what you might change within teleop.vi.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 03-02-2010, 16:07
I am error's Avatar
The Error
Thanks..., but can you also show the rotation to? Thanks again
I am Error. Yes.
Unread 03-02-2010, 16:25
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
where would i find polar to rect
Unread 04-02-2010, 17:08
I am error's Avatar
The Error
There should be a picture attached of our FAILING holonomic drive example. There is a boolean that leads into the case statement you see there. This is so we can have a false case where the robot flips out (as a test) and then the true case that is our actual program. The inputs are just constants in the false case, but not in the true case shown below. The robot will drive in circles when I tell it too (the false case), but when set up like below, it doesn't work. Why is this? Does it have to do with the scalar input? Please help!
I am Error. Yes.
Unread 04-02-2010, 21:08
When it doesn't work, what does it do?
It might be helpful to see what is in the false case.
Unread 05-02-2010, 08:22
dwodrich dwodrich is offline
FRC #1706
dwodrich has a spectacular aura aboutdwodrich has a spectacular aura aboutdwodrich has a spectacular aura about
I would double check the location of every motor/PWM and make sure it is where the program thinks it is. Also you probably need to invert the left side, if your motors are mirrors of each other.
Unread 12-02-2010, 15:15
I am error's Avatar
The Error
this is the false case, and it is operating like this because the highlighted connector is set to false. It's for testing only. As you can see, it is set to drive around in circles, and it does that. But when you switch to the true case, it fails and DOES NOTHING. Therefore, the error is likely in the true case.
I am Error. Yes.
Unread 12-02-2010, 15:32
What is LeftStick? It doesn't appear to have a value. Without a proper USB# there when you run the code, I think the Joystick Open will fail.
Note that changing the value of the control after the vi is running will do nothing helpful. The Joystick Open has already been executed, and the invalid reference being fed to the Joystick Get will not change.
Either replace the control with a constant and set it appropriately, or set the control to the right value and choose "make default" before you run the vi.
Holonomic Drive Help star_lancer NI LabVIEW 2 01-02-2010 22:39
Switching to Holonomic Drive MachineSMMC NI LabVIEW 1 22-01-2010 13:07
Holonomic drive and ramp robotaddict Technical Discussion 11 13-01-2006 16:57
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
Holonomic Drive Mathmatics Discussion robotaddict Programming 35 15-10-2005 13:29
