Re: Invariant FPGA Image Version Error?
Here are 5 other reboots for ya (i think you may be right):
cRIO-907x Boot
Copyright 2007 National Instruments Corp.
Bootrom version: 2.4.7
Creation date: Jul 9 2007, 00:45:07
_
Press any key to stop auto-boot...
auto-booting...
boot device : tffs=0,0
unit number : 0
processor number : 0
host name : host
file name : /c/ni-rt/system/vxWorks
flags (f) : 0x8
Mounting tffs...
Attaching to TFFS... Datalight Reliance v3.00.1218T
VxWorks Edition for ppc603
Copyright (c) 2003-2007 Datalight, Inc.
done.
3572144
Starting at 0x100000...
ATA device not detected.
Adding 8459 symbols for standalone.
Mounting onboard storage...
Reliance File System Driver
Datalight Reliance v3.2.2 Build 1376BV
Copyright (c) 2003-2008 Datalight, Inc. All Rights Reserved Worldwide.
-> lvusEngine: PPC603 CPU detected...
CPU tick frequency: 33.000741 MHz [Using: 1000 MHz]
MAX system identification name: Team25
Initializing network...
Device 1 - MAC addr: 00:80:2F:11:5A:D1 - 10.0.25.2 /8 (primary - static)
Device 2 - MAC addr: 00:80:2F:11:5A:D2 - 192.168.0.3 /24 (static)
Loading LVRT...
* Loading EarlyStartupLibraries: tsengine
Time sync source: rtc now active
* Loading StartupDlls: debug
Entering debug.o StartupLibraryInit
Debugging is up, target server mounted at /tsfs
VxWorks
Copyright 1984-2006 Wind River Systems, Inc.
CPU: MPC5200 -- Wind River Lite5200 BSP.
Runtime Name: VxWorks
Runtime Version: 6.3
BSP version: 2.0/10
Created: Jul 29 2009, 13:41:47
ED&R Policy Mode: Deployed
WDB Comm Type: WDB_COMM_END
WDB: Ready.
Leaving debug.o StartupLibraryInit
* Loading StartupDlls: NiRioRpc
* Loading StartupDlls: niorbs
* Loading StartupDlls: NiViSrvr
* Loading StartupDlls: nivissvc
task 0xec2cd8 (PAL00f94078) deleted: errno=0 (0) status=0 (0)
NI-RIO Server 3.2 started successfully.
task 0xc3e130 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
* Loading StartupDlls: nivision
* Loading StartupDlls: niserial
* Loading StartupDlls: FRC_FPGA
* Loading StartupDlls: FRC_NetworkCommunication
FRC_NetworkCommunication was compiled from SVN revision 2123
Error, Invariant FPGA image version error! (-63194)
FPGA Hardware GUID: 0x0AF07C6B1E53E3F869DC0EE6C45E6FA9
FPGA Software GUID: 0x1E53E3F869DC0EE6C45E6FA90AF07C6B
FPGA Hardware Version: 49391
FPGA Software Version: 49391
FPGA Hardware Revision: 1.0.0
FPGA Software Revision: 1.0.0
FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
FPGA Hardware Version: 2010
FPGA Software Version: 2010
FPGA Hardware Revision: 1.3.0
FPGA Software Revision: 1.3.0
* Loading StartupDlls: FRC_UserProgram
ERROR: Network communication failed to initialize!
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000718 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2d58 (PAL00f940b8) deleted: errno=0 (0) status=0 (0)
task 0xc3e1a8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
FPGA Hardware GUID: 0x1E53E3F869DC0EE6C45E6FA90AF07C6B
FPGA Hardware GUID: 0x00000000000000000000000000000000
WPILib was compiled from SVN revision 2069
task 0x219ab60 (t2) deleted: errno=0 (0) status=0 (0)
Welcome to LabVIEW Real-Time 8.6.1f2
NI-VISA Server 4.5 started successfully.
task 0xe41540 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
Default Disabled() method... Overload me!
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000699 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2bb8 (PAL00f94038) deleted: errno=0 (0) status=0 (0)
task 0xc3e0f8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
FPGA Hardware GUID: 0xB57A549EAD9A5591CC64E4DF756D77D1
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000693 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2dd8 (PAL00f94178) deleted: errno=0 (0) status=0 (0)
task 0xc3e230 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000689 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2e48 (PAL00f941e8) deleted: errno=0 (0) status=0 (0)
task 0xc3e298 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
Let's see if my profile changes take effect now...
Sorry but I was the AE that you talked to on the phone just a little bit ago. There isn't any contact information for your Team Advisor so I couldn't call you guys back so I thought I would post back here since I told you to monitor it. I talked with Joe about the issue and we think that it is probably something hardware related because it looks like the FPGA doesn't register properly. It looks like the booting multiple times is also pointing to the same thing. Give us a call and we can pick up the troubleshooting again. Thanks!! |
Just to satisfy my curiosity, what caused those Watchdog.cpp errors in the data I posted in the first post of this topic?
The Watchdog class uses the FPGA chip object interface like all others. One of the first things each class does is check that the FPGA is the right version for the class. If the GUID reads fail, it won't match and will return that same version mismatch error.
Joe-
This is the head coach for 25. I spoke to NI yesterday after Phil was on for quite a while and they want us to return the unit. They were to be sending us a cRIO and we are supposed to return our unit in the box once it arrives. However they had no idea when or if another cRIO would be available any time soon. Time is of the essence here. We cannot afford even a few days lost. Do you have any idea whether units are/will be available in the next day or so? Apparently we cant even buy a new one. WC |
Hi guys -
There has been some confusion on this and so the following will be in the team update going out tomorrow: Teams that need to send their cRIO-FRC back to National Instruments for repair will get a replacement sent overnight to them if it is in NI's system before 4pm Central, otherwise it will be processed and overnighted the next day. NOTE: This is at the mercy of other teams however. We only have so many in stock and if teams that request this do not send theirs back to get repaired in a timely matter, our stock can get low. We are currently fine though. Teams purchasing spare or extra cRIOs will receive their systems in approximately 2 weeks. Let me know if you have any particular questions on here or via email (see below). Thanks! |
#7
Thanks NI-
today I had numerous contacts with your people and confusion from yesterday was cleared up. The cRIO replacement is on the way. Your staff handled it all with compassion and I thank you for it. WC |
| Error "IFI>Master Code Version: 8 " | mecanumbot | Programming | 0 | 24-01-2010 01:30 |
| cRIO Image version? | Chris11246 | Programming | 1 | 14-02-2009 16:44 |
| v11 cRIO Image Error | Team1710 | Programming | 7 | 14-02-2009 12:56 |
| FPGA Image | idahorobot | FRC Control System | 1 | 12-02-2009 01:23 |
| Error in Compiling the Camera Code (B&W Version) | VetteSlick | Programming | 7 | 20-01-2006 20:50 |
