Go to Post The best way to build a brand is to win. - Tom Bottiglieri [more]
Unread 03-02-2010, 16:58
Letsroll Letsroll is offline
FTC #3944
Letsroll is an unknown quantity at this point
[FTC]: Chain Help?
My Team is using chain and we need to add chain links back on... is this possible?
Unread 05-02-2010, 16:32
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Chain Help?
This decreases the strength of the chain, but you could easily just use master links to connect more pieces together or half-links if needed.
I believe that is the easiest way to do it from what I have learned
Hope this helps
Andrew
Team 1902
help with inventor chain??? CY83R W01V35 Inventor 2 23-01-2010 12:53
[FTC]: Chain Break Andrew Remmers FIRST Tech Challenge 2 18-10-2009 11:34
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: [FTC]: HELP! Multiple fields set up!!! galewind FIRST Tech Challenge 10 16-12-2007 09:53
~Help~ (Inventor-chain) moses Inventor 1 07-02-2006 11:12
