Go to Post I openly admitted to using IE at robotics last year and recieved a major lashing for such blasphemy. Then I downloaded Chrome. - jwallace15 [more]
Unread 03-02-2010, 17:36
regiquest regiquest is offline
FRC #1677
regiquest is an unknown quantity at this point
Cool Falling Robot Perimeter
We were discussing how to right the robot when we came up with the following question:Is it okay to extand past the perimeter of your robot to prevent yourself from falling if you are about to tip over?I know that you can extend up to the final configuration if your robot has fallen, but what about if you think its going to fall, but it hasn't fallen yet?
Unread 03-02-2010, 17:44
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Re: Falling Robot Perimeter
You can only extend past the perimeter limitations in order to right yourself. You may not breach these limitations to prevent yourself from falling. ONLY to right yourself (and to hang during the last 20 seconds).
Unread 03-02-2010, 17:47
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
It might be worth the 1 point penalty to just quickly right yourself so you continue to score. If you waste time to right yourself when you are completely down, you may lose valuable time to score.
Unread 03-02-2010, 17:50
V_Chip's Avatar
Back in action.
AKA: Victor
However if you do aim to prevent your bot from falling, and accept the consequences of a penalty, you must be sure that your righting/fall prevention system can handle the impact of a falling 120lb robot.
Robot Design: Frame Perimeter? IamMisplaced Technical Discussion 7 17-01-2010 15:03
Frame Perimeter? jimbot General Forum 2 10-01-2010 13:48
BUMPER PERIMETER GaryVoshol Rules/Strategy 25 27-01-2009 22:55
Holding of Game-Pieces Outside the Robot Perimeter MikePres General Forum 2 24-01-2009 07:21
Falling Robot Mullen Technical Discussion 1 16-01-2003 16:38
