Go to Post Life isn't a set track: you have to go out and make your own path. - Greg Marra [more]
Unread 03-02-2010, 19:25
just_wondering just_wondering is offline
Newbie :)
FRC #3202 (Knightbots)
just_wondering is an unknown quantity at this point
Unhappy Sequences
We are trying to program the motor to go forward a certain speed and then go back. We put this in sequence and there is an error. Please help. The following attachment is our program
Unread 03-02-2010, 22:22
Re: Sequences
The red X with two arrow heads point towards it indicates that two data sources are connected together. In this diagram, the constant produces data and so does the subVI outside the sequence.
What was the desired effect of connecting those together?
Greg McKaskle
Unread 03-02-2010, 23:11
Re: Sequences
Is this something like what you wanted? (Note that it doesn't feed the watchdog. You'll need to do that if you want to do things this way.)
Unread 05-02-2010, 08:24
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Re: Sequences
however *don't quote me on this* if you put this in your teleop, or auto or whatever you are putting it into, you can't use a wait vi because it halts the rest of your program. I wrote a state machine to do this so that the code continuously loops, but can still be timed. If you want some more info, go to LVmastery.com and look at the state machine tutorial.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 05-02-2010, 16:09
Newbie :)
Re: Sequences
That is what I wanted thanks!!!
PrintToScreen vs printf escape sequences rwood359 Programming 0 02-09-2008 15:18
RC Secret Key Sequences tdlrali Programming 9 05-02-2007 07:16
